UPDATE - Marschmallow - Wasser Firmware for Beelink R89
Originally posted by digitalriver View Post
might you have webcam with microphone? That mic works, doesnt work internal mic. Im also have webcam with microphone, and all works, for example - in Skype. But some people dont have mic in webcam.
The internal microphone is working.
Originally posted by bloodgnome View Post
Great work. Thanks amclean123.
The last Lolipop Version would be cool too.
Do you think this will work with Amlogic devices too as I have a S905 Device with proably broken EMMc. It flashes from SD fine so its not totaly bricked. But sadly it just flashes and doesn't boot the Firmware from SD.
Greetings.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by uli-hh View Post
I've a webcam with mic, but it is not plugged to the box (Beelink R89).
The internal microphone is working.Ubox R89 2/16Go(5v4a) + Tv panasonic 32 Full HD + Airmouse c120 + 1To 2.5 Toshiba HD.
Originally posted by mackie View Post
Do you a menu in settings about the Mic? because even Ok google is not working and I don't have the Mic icone in the search bar.
Originally posted by brolo90 View PostNew here and just starting out with my Rockchip firefly 3288. Was able to flash 4.0.11 MM. Will be trying some Overclocking settings.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Good day dear Wasser .
Why do the firmware to an older version of Android 6when there is Android 7.1.1 is not better in this version to import the driver and everything will work than the old version of Android 6.
CarbonROM command you can give the source code for Android 7.1.1
The source code is free.
Originally posted by User_RU View PostWhy do the firmware to an older version of Android 6
Besides. As far as I know there will be RK3288 Nougat SDK released by Rockchip. Therefore it is quite possible that Wasser will release new ROM for this quite old device. I think donations would help.
Last edited by Gormar; 04 January 2017, 10:24.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 2116 users online. 0 members and 2116 guests.
