UPDATE - Marschmallow - Wasser Firmware for Beelink R89
    Thanks Gormar, I just got round to trying your suggestion. After connecting my Ethernet adapter I get the following in dmesg
    USB 3-1: device not accepting address 6, error -110
    Indeed it is in host mode hprt0 = 00001500
    Indeed it is in host mode hprt0 = 00001501
    Note that it is actually not an R89 I'm using this ROM on but an MK903V. Although the ROM appears to work perfectly other than Ethernet.
    Actually forget that initial message , I tried disconnecting and reconnecting again and get a different result. The product is identified correctly as an AX88x72A but I still can't seem to activate Ethernet.
      When you connect external Ethernet adapter does it appear in "ip link" list?
      RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
        I checked the output of IP link before and after connecting the adapter but there was no change. There is an eth0 entry but it's state is 'down'.
        I also tried changing the USB mode in developer options to RNDIS which resulted in an rndis0 line being added but that is in a 'down' state also.
          Hello everybody,
          First of all thanks to wasser for the extraordinary work he have done!
          Second I would like to ask about an issue.
          I have installed the 4.0.11 rom to a Tronsmart R28 and I am 99,99% satisfied.
          The 0,01 percent refers to the non working remote.
          Is there a possible fix for it? is there any guide available?
          Is there any recommendation about another working remote with this rom?
          thank you in advance for your time!
            Hello Pavlitos80. I'm affraid that Tronsmart changed theirs remote send with Orion R28 TV Box. There is a solution but someone has to send you modified resource.img.
            This is new remote:
            http://image1.geekbuying.com/content...0153208988.jpg
            There is old one which is also used by Beelink R89:
              Good morning Gormar and thank you for your quick reply!
              So either I get used with a simple mouse for android interface and Kore/Yatse for Kodi or I should get a decent air remote control that will solve all those problems.
              I don't see any other easy solution!
              It's just a pitty that the original is wasted!
              Anyway we can't have it all!
              Thank you for the quick answer and Kudos to wasser for all the hard work!
                Hello, thank WASER, I have use your custom rom for my Tronsmart Meta Orion R28, it's working great.
                I had just a little issue about the wifi speed connection. it was connected to 5Ghz at 200 Mbit/s, after searching into the forum, I have just changed the Wifi Region from Europe to US and now it is at 390 Mbit/s
                Have a nice day. thank you very much
                  danway, i have the same problem, where can I find the WIFI region?
                    Hi ,
                    not sure but i think in the "build.prob" File , you have to change this ???
                    nice Day
                    gefattern
                      to specify the region code for WIFI (Settings->Wifi->Advanced Wi-Fi->Wi-Fi region code)
                      Envoyé de mon C6503 en utilisant Tapatalk
                      Ubox R89 2/16Go(5v4a) + Tv panasonic 32 Full HD + Airmouse c120 + 1To 2.5 Toshiba HD.
                        wasser
                        Hi wasser as a great fan of your excellent roms I'm using the marshmallow v. 4.0.11 on my Beelink R89 box and the marshmallow 64bit v. 4.0.2 on my Beelink i68 box. For me everything is running fine beside the Tagesschau 2.0 app.
                        On the i68 the app is working fine:
Name:	Screenshot_Tagesschau 2.0 i68.png
                        but on the R89 there is a problem:
Name:	Screenshot Tagesschau 2.0 R89.png
                          Hi to all ,
                          is he still there ??? Why no answer is coming back ???
                          Maybe he works on something GREAT ???
                          hope all is good with him , he makes good work.
                          nice Day to all
                          gefattern
                            Originally posted by gefattern
                            Hi to all ,
                            Well Wasser isn't really a chatty one.
                            As far as what he is doning in real life or whatever he does else or works on (new boxes? Rk3399? Another update for rk3288 or rk3368) nobody knows.
                            We only know that he is german and that he makes awesome stuff for boxes that would otherwise be far from their potential. Like the stuttering mess the b89 was (official is still on kitkat) before he startet with his mods.
                            So to sum it up: He is the silent and humble Messias of Rockchip TvBoxes
                            Would really like more info of him... Maybe a paetron page ore something else.
                            Gesendet von meinem Redmi Note 3 mit Tapatalk
                              Hi, I have Ugoos UT3 and have problem with sound output. I'm using analog A/V output (not HDMI or SPDIF) and try all 3 kind of output in system settings: system default, spdif and HDMI output, but none of them works - no sound. Original fw from ugoos works with no problem with A/V output. Is there any solution to resolve that problem, because I really need marchmellow on my Ugoos
                                Hi H-Tab ,
                                i have a UT3 too and if i can remember good i always had no Audio on latest Wasser Roms too ,
                                to different FW parts or HW parts ???
                                All UT3 Users have to wait till Ugoos will release Android 7 and Chrome OS , like they promised
                                weeks before . ( 2 Weeks like they said on there Site , until now 2 Month ) , we have to wait till
                                Month 6/7 maybe ???
                                nice Day to all
                                ​​​​​​​gefattern
