UPDATE - Marschmallow - Wasser Firmware for Beelink R89
i updated from a good old 2.x version of wasser firmware but now i got no hdmi passthrough for DTS/AC3.
Could somone please tell me what i need to do to get sound working ?
i set in normal android settings to hdmi bitsream audio device and in rkmc i enabled passthrough. Or is some other mediacenter like spmc or kodi better ?
bets regards,
Thomas
bets regards,
Thomas
Or wait for Nougat firmware that will be released for some RK3288 devices in a few weeks.
There are audio bugs in early RK3288 Marshmallow firmware that was only fixed in *L/M Marshmallow versions from Dec-Feb 2017.
You can check the build.prop file to see the build info, Marshmallow version and the letter it ends in.
I think it will be 'K'.
Originally posted by FunThomas View Postthanx for the fast response
Do you know what version of wasser 4.x was the latest working for hdmi passthrough ?
is it possible to find out without flashing the image and watch the build.prop ?
The only way is to test and flash all of them or go back to Lollipop and then know for sure it will work.
ok thanx
edit:
with wasser 3.0.6 i have problems with stuttering in playback and then switching audio from dolby digital to stereo without sound
i think the best way is to throw this crappy hw away and buy some better new one with better fw support for high quality audio in kodiLast edited by FunThomas; 05-22-2017, 12:52.
Hi
So finally I upgraded my old original firmware to this one (4.0.11)
- My config: Beelink R89 to Yamaha RX-677 with 5.1 speakers and 4K low-end TV (TCL), ethernet on CPL
- New Kodi to replace my old XBMC, so nice!
- But no passthrough through HDMI anymore :-(
- I purchased a SPDIF optical cable and got 5.1 back. Config needed: passthrough SPDIF in Android setup, Kodi audio: 2.0, passthrough AC3, DTS and transcode
- So now AC3, DTS and AAC any channel work with expected channels
- Some glitches: screen goes black 3 seconds and back. Solved by removing : "adapt sync etc." (?)
But good experience overall! Thanks Wasser.
Originally posted by scooter2014 View PostThere lots of videos on line you tube. But making sure drivers installed and that your pressing the rest switch and holding when plugging into usb port for flashing.
https://youtu.be/6A_-ataMLus
Originally posted by GreenGirl View Post
Scooter, what about updating S905 chipsets or older chipsets, NOT rockchips sets (I would never buy rockchip boxes for several reasons) however I would love to be able to update Amlogic S805 & Amlogic S905 & S905-X chipsets if possible & thank you in advance for your knowledge
Hello to you al, I Richard from holland I use this firmware on the ugoos cx998 a rebranded sunchip box and it works perfectly no video frame glitch.
I want to ask wasser wy I can not switch to 4k resolution I can see it and select it but it does not work it only stay in 1080p that the highest resolution I can select in this wonderfull firmware I have a 4 panasonic tv so I like to switch to 4k. .
Thanks for your effort on this forum.
I fixed it it was a bad hdmi cableLast edited by astromar99; 07-07-2017, 16:03.
There are currently 2333 users online. 5 members and 2328 guests.
