- fixed sound issue for latest RKMC
- improved stability for the latest RKMC and othe media player apps
- fixed menu issue in google play video and vlc
- added HDMI CEC support
- fixed many security issues
- updated google apps
version 4.0.10
- fixed crash in camera
- added support hdmi hdcp 2.2
- fixed sound issues
- improved the video streaming and stability for the latest RKMC and othe media player apps
- fixed playing video issue in browser
- updated google apps and Superuser
version 4.0.9
- enabled "adjust display refresh rate" by default
- added menu for Color mode which allows the user to specify the color mode (Settings->Display->Color mode)
- fixed USB camera and another USB issue
- improved the streaming amazon instant video
- fixed issue in 4K 50/60HZ again (please test)
version 4.0.8
- disabled initial lock screen
- added menu to specify the region code for WIFI (Settings->Wifi->Advanced Wi-Fi->Wi-Fi region code)
- fixed issue in HDMI Bitstream (i don't have the equipment to test this! please test yourself and give the feedbacks)
- improved nfs mount
version 4.0.7
- fixed crash in Settings->Display
- fixed issue in playing video from google drive
- fixed the state of "connect to usb" which is lost after reboot
version 4.0.6
- fixed TVOUT issue
- fixed HDMI audio regression
- added option advanced reboot, it allows to enable/disable reboot in recovery, booloader in power menu
- fixed sleep issue
version 4.0.5 rc2
- fixed SPDIF Passthrough issue
- added menu option to allow (un)root the device (menu Developer options->Root access)
- added menu option to hide the hdmi screen, it's required for DRM apps (menu Settings->Display->HDMI checking)
- added support "Adjust display refresh rate"
- fixed regression (DTS/DOLBY) from rc1
- fixed issue in playing 10 bit video
- made RKMC working
version 4.0.4 rc1
- fixed issue "wifi doesn't support channels above 12"
- fixed analog audio output distortion after longer sleep/suspend duration
- improve HDMI settings and screen scale setting (move HDMI setting to Display Setting)
- added lockscreen support
- updated es file manage
- fixed many other minor issues
version 4.0.3 beta3
- fixed issue in exfat filesystem
- added reboot to recovery and bootloader
- added softreboot
- added sdcard support
- added camera support
- added multi-windows mode
- fixed wake up issue
- fixed youtube cannot play1080p 60fps
- added sound devices manager for setting SPDIF Passthrough and HDMI Bitstream
- fixed TVOUT issue
- fixed many other issues
version 4.0.1 beta1
- added exfat filesystem support
- added xposed support
- added hide/show navigation and statusbar
- added poweroff button in navigation bar
- improved UI
- added "clear all recent apps" button
- fixed ramdom ethernet MAC adress
- added menu option for "Connect to PC"
- added rotation support
- fixed root device
- fixed virtual mouse by using ir-remote
- fixed bootloop issue by flashing of new firmware
- fixed one issue in init.d
version 4.0.0 alpha1
- firmware based on marschmallow 6.0.1
- support HDMI sound
- support tvout
- support ethernet
- support wifi
- support bluetooth
- support LED
- support ir remote
- init.d support
- nfs filesystem support
- multiuser support
- add statusbar, navbar
- google apps
- support netflix, google play video
and many features are still missing in this release. Please report feedbacks so i can improve it in future release. Thanks
Firmware download: wasser-firmware-mmallow-4.0.0-alpha1
Howto get log files: get-a-logfile
