UPDATE - Marschmallow - Wasser Firmware for Beelink R89
    Flashed the kernel and got Dolby and DTS back.
    Had to switch back to default output and then back again to get it to work.
      Hello Wasser,
      Did You add back in adb to version 4.0.4 rc1
      thanks
      3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
      CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
      Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
      Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
        I had to go back to 4.0.3 because of the lack of sound true the AV port. At the beginning I had sound but after 30-40 minutes the sound has gone, I restart the sistem 2 or 3 times but again after 3-4 minutes the sound disaper again.
          Thanks wasser for your effort... using mxplayer 1.7.40 with spdif passthrough on mm 4.0.4 i had frequent video playback jitters and stutters almost every 2-3 sec. and no DTS and DD audio...
            could you please try to flash the kernel from beta3 and check again if it fixes the obove issues. It's very important infos for me!
              hi wasser , unfortunately even after flashing with the beta 3 kernel , the same issues are still present (with spdif passthrough on ; frequent video playback jitters and stutters almost every 2-3 sec. and no DTS and DD audio using mx player 1.7.40 and even on superceleron's kodi 16.1)... thanks
                Did you have SPDIF passthrough available with the previous release?
                I take it that you are using neon.1.7.32.rev1 codec?
                  Try ES File Explorer's video player. It worked really well with 5.1 DD and DTS. It may become my new video player. I had problems with MX Player and plan to reflash and test again tonight.
                  Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
                    After erasing 3 times I can now access the Display settings.
                      I echo that.
                      The ES Media Player does very well and the only formats not recognised are .ts and .m2ts
                        I loaded RC1 tonight and I really like it! I didn't erase Beta 3. I just upgraded to RC1. I don't know if that matters.
                        Here's what works well:
                        Youtube 4K
                        MX Player with 1.8 codec
                        ES Media Player (Part of ES File Explorer)
                        BT
                        Ethernet
                        Here's what needs fixing:
                        Using HDMI passthrough audio if you skip the MKV video ahead a few minutes you'll lose audio. MX Player and ES Media Player both have this issue. If you kill off the app you get your sound back.
                        I will try my tests with SPDIF out and see what I can find.
                          Youtube 4K
                          BT
                          Ethernet
                          I ran some tests of MKV files with HDMI passthrough and although I could replicate the lost sound, it was not consistent.
                          Sometimes I would lose sound, sometimes I would get crackle and hiss and sometimes it would be fine.
                          Also noted that when I either get no sound or crackle and hiss that playing another file for a few seconds and then returning restored the sound correctly.
                          Can't fathom out any clear pattern as it can happen on files with varying audio tracks but found it mainly to be with 5.1 and DTS.
                            hi bluesmanuk , i never tried any of the previous MM firmware.
                            yeah , mxplayer 1.7.40 uses either 1.7.32 or 1.7.32rev1 and trying both codecs resulted in no audio when enabling spdif passthrough.... video playback is also super jerky , despite how vivid and crisp the actual video appears as you mentioned. thanks bro... and a big thanks to wasser too since i've always been a fan of his unparalleled effort and work...
                              I tested SPDIF audio out and Default audio on all of the MM roms here and I can't get it to work on my Tronsmart R28 or Beelink. I tried it on 3 Yamaha receivers and 1 Pioneer receiver. The video won't play either on any app when Default audio or SPDIF is selected. It's not an issue for me. Just an FYI. HDMI audio output works great for me on those receivers.
                                What audio receiver? My receivers are all 4+ years old and seem to work just fine unless the video is skipped forward. I only tried Youtube, MX Player, ES Player, PBS Kids.
