The good of these latest posts here, discussing about it, it´s to recognize that there is a real "restriction" here that makes that some people still prefer LP firmwares instead of this newest wasser MM; but either what it´s your choice, this overcome the problem, the solution is reachable. Having installed xposed I personally prefer the app "marsmallow SD fix - root" because it´s application selectable and you can revert easily the permission if you like it, leaving the system untouched; and the most important, this app it´s working wonderfully with wasser MM. So, knowing how brilliant it´s wasser developing these roms sure he can implement a "swicht" to grant permissions to all of the applications to write to external storage o can be reverted when required, i.e adding into "Developer options" this feature.
Regarding to sopcast, the full working version is v1.1.0 which is much older that the version from feb/2015 (v1.2.8 and v1.2.4 do not work), however it´s the version that works in wasser MM.
