UPDATE - Marschmallow - Wasser Firmware for Beelink R89
    I have now found that the maximum resolution that I can achieve is 3840x2160p-30
    Any higher and the screen just goes blank.
    I have found a fix for the USB connectivity always defaulting to charging instead of my chosen preference, MTP.
    Edit the build.prop where is shows persist.sys.usb.config=,adb and alter it to persist.sys.usb.config=mtp,adb
    This will be retained after a reboot.
      Did you carry out an erase before flashing?
      no I will try next time
      Originally posted by Ben.Efrati View Post
      Interlaced videos doesn't work with RockChip Codec. you need to disable Rockchip Codec and use mediacodec instead
      Thank you
      It is necessary to solve the problem with the advent of sound within at ZDMC
      The cooling system on Tronsmart Orion R28 Meta Wasser2.0.9a)
        Thanks for your efforts. Two regressions in 4.0.9 with respect to the Lollipop firmware, and a common problem
        1. With an Atrix Lapdock, the available resolutions are down to 720x520 (or 480) (or something about those resolutions). With the Lollipop firmware, a nice enough res was selected (either 720p, or HHHx736). Quite notable, using an app that forces the resolution results into a better (and random) resolution (with some random side-effects)
        2. The sound output was constantly HDMI + SPDIF in Lollipop, irrespective of the selection in Sound Device Manager. Now, it is HDMI-only, and once again the selected device in Sound Device Manager has no effec (I am using YouTube in my tests)
        A third point is that cheap USB sound devices do not work either.
        Thanks for any help !
        DKCM
          I have never known HDMI + SPDIF to be both available regardless of what is selected, although I have never actually had reason to check for sure.
          I would certainly expect each option to operate independently as that would be the desired effect.
          Can't you just select SPDIF in 4.0.9?
          I tested SPDIF and it worked for me using MXPlayer.
            Using the latest 4.0.9 and Supercelerons 16.1 (RC3) everytime i start a movie i get no sound (HDMI Bitstream).
            When i pause the movie 2 times for a couple of seconds and press play then the sound returns....other video apps like amazon video work fine.
            Other than that a allmost perfect rom. Even the TV Out works finally YAY.
            EDIT:
            Seems to be a problem with the Superceleron Mod of Kodi 16 (Possibly RK Kodi too). As SMPC doesn't have it. I will test the normal Kodi and see if it happens there too or not.
              EDIT:
              bloognome, I also have the same exact problem with the latest normal Kodi, anxious for your findings.
                I hope the above problems are gone in the next update.I wane try this rom on my beelink but i still run Kitkat..I saw a few post before about updates from other updates or from Lollipop.But is there somewhere an explanation how to upgrade to marschmallow..Or from a clean way, or can i just go from Kitkat to this rom..I will check Kitkat to see from where i wanne do this..And is there already any benefit in sounds with marschmallow?
                Thanks.
                  I've upgraded to Kitkat just fine to 4.0.9 and had no problems at all.
                  Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
                    Will this firmware work on Tronsmart R28 Pro
                    2G/8gb? Currently on stock Kitkat rom.
                      Yes. I've done it many times for that configuration.
                        Thanks for the answer...Then ill hope wasser will make another updated Marschmallow rom....And a deeper question....Witch will not be answerd ill quess.....How is the spdif sound, and......Any higer rates already possible true spdif ......
                          Hi can I use this version Orbsmart S92 here for my TV box?
                          Here a link to the box: http://www.myhdplayer.de/Orbsmart-S92-Android-51-Quad-Core-Mini-PC-4K-Ultra-HD-MediaPlayer-Smart-TV-Box
                          Or are there other ROMs?
                          Thank you for an answer!
                          Greetings Armin
                            I think the sound is incredible on Marshmallow. I do think it is better than Kitkat. I'm very picky about the sound. If you need help flashing, this is the way I flash mine. https://www.youtube.com/watch?v=K9lLJirKEIQ
                              did you mean me now amclean123?
                              Running this version also on the ORBSMART S92?
                              Thank you
                                Quick question, I'm on Wasser Lollipop and want to upgrade to this Marshmallow build. Can I upgrade remotely (i.e. transfer the file to the box and upgrade without plugging the PC)?
