My many thks to my 2 beta testers trebor and scooter2014
Changelog v1.0:
- Build from the source. (no its not based in any of the roms that the manufacturer rls for it, its brand new)
- Youtube fixed 720/1080p (original rom's only 360p max)
- Netflix playstore...etc... fully working
- DRM widevine!
- Bottom bar fixed and added power button to it.
- Proper rooted.
- Twrp recovery. (thks abdul_pt)
- Custom Kodi 16.1 Build. (Normal Kodi with my librtmp)
- initd.d support.
- Fully deodexed.
- Network tweaks. (On N networks bw around 30 to 39mbits, and on AC networks from 40 to 49mbits)
- Permissions fixed.
- Sleep working, full poweroff also working.
- Google core framework etc etc... updated
- Removed the default launcher it have a lot of stability problems, so you will lose the led color change since its the launcher that controls it!
- Added a custom launcher, small changes to it.
- Other small fixes and optimizations!
- QBOX_2GB_16GB_Superceleron_v1.0_Final
- MD5: 3BDFD535E6037425C27C4176D3BE4F94
- 1) Use USB_Burning_Tool 2.0.7 minimal (grab it here http://freak-tab.de/luis/setup_v2.0....2_12Device.zip )
- 1.1) Un-Check "Range" in temperature setting (its in "View")
- 2) Install it and the driver, open the program and select the rom img.
- 2.1) Use a USB A to USB A cable of good quality (needed to power the box with it and of course flash...)
- 2.2) use the inner USB port (the one next to the hdmi socket)
- 3) Put a toothpick in the phones/tvout socket and press it and connect the usb cable to the usb port and keep it pressed until the program detect the box! (Some boxes may need the powersupply)
- 4) Flash it!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
