[ROM] QBOX 2GB/16GB Superceleron v1.0
superceleron ok, so i've just flashed your rom and surprise, it does not see the contents of my external 1tb samsung usb hdd. it shows it on the storage list, but no contents. well, that's a bit of a problem for me i'd say, as that's where i have all my media files. so, for now, back to the stock rom where it was working just fine. damn, all that time i spent to configure that stock rom as i wanted, now i have to do it all over again. i'll try your rom again once this issue is sorted. let me know if there's something i can change or do, files that i would need to open, edit or whatever, inside this rom as it is on the device! thanks!
The rom works great,much faster than the stock rom. I have seen no problems what so ever. And the people having issues with flashing their units,it is nothing more than poor quality cables and trying to flash using windows 8 or higher.I am running windows 7 32bit and have never had a failed burn on a box recently. I had one box that was junk from day 1. M8S is about as poor as you can get for quality. Don't buy cheap USB cables from ****,that is most of your problems. I bought my cable through Newegg and it works fine. I am not affiliated with newegg what so ever,just buy quality products from them.
Originally posted by carianis View Postsuperceleron ok, so i've just flashed your rom and surprise, it does not see the contents of my external 1tb samsung usb hdd. it shows it on the storage list, but no contents. well, that's a bit of a problem for me i'd say, as that's where i have all my media files. so, for now, back to the stock rom where it was working just fine. damn, all that time i spent to configure that stock rom as i wanted, now i have to do it all over again. i'll try your rom again once this issue is sorted. let me know if there's something i can change or do, files that i would need to open, edit or whatever, inside this rom as it is on the device! thanks!
Originally posted by abdul_pt View PostRecovery log please.
Tapatalked
I've attached the log.
Originally posted by superceleron View PostYes i know
And yes u can, and is pretty simple to do it!
You need it from the original rom, and transplant it to this one!
Sorry, was out during a while.
Did not find a way to open your img to perform a switch.
Would it be possible that you post this rom in the same format as your "SC_v1.0_OTT_MXQs905" ?
Code:==> extracting: /system//app/Bluetooth/lib/arm/libbluetooth_jni.so (symlink to /system/lib/libbluetooth_jni.so) ==> extracting: /system//app/Bluetooth/lib/arm/libbluetooth_jni.so (link to /system//system/lib/libbluetooth_jni.so) tar_extract_hardlink(): failed restore of hardlink '/system//app/Bluetooth/lib/arm/libbluetooth_jni.so' but returning as if nothing bad happened tar_extract_file(): failed to set permissions on /system//app/Bluetooth/lib/arm/libbluetooth_jni.so !!!
Originally posted by trebor View Post
Do I have to open the box to get to that button?
It's not this one? http://imgur.com/1iUjOBZ
i tried that, and it gives the clicking sound when i press it and hold it in, but the burning tool does not find it
edit: I got a little further, but it failed 2 times, it will eventually succeed?: http://i.imgur.com/dPm7WNz.png
edit2 : science!it succeded!
superceleron, can you accept bitcoins as donation? then i gladly donate 10$ for a few beers ^^
then
There are currently 3097 users online. 2 members and 3095 guests.
