[ROM] QBOX 2GB/16GB Superceleron v1.0
Originally posted by Markie13 View PostHi there.
I need some help with my connection to my pc. I'm trying now for 2 days to connect my QBox to my Laptop/GamePC/HTPC (both 3) as described in the first post. With toothpick and power up via USB many times (it start up with only usb3 connected). Then in combination with the power adapter and this on 3 PCś with windows 10 Pro and home.
Is it possible to do this with a SD card and how? (please explane this in noob language)
Regards
Mark
ps. in windows device manager nothing appears!
Hello again cant wait for mod for 2g8g so bought another q box 2g16g and flashed with Your rom, works just great just found 1 issue when installing more apps they are not shown on my apps screen have to acces by es file explorer. Now one very important question propably not only for me: is there any chances to get google voice search get to work , get system to detect and use usb mic?
I'm considering updating to this ROM. But for a very specific reason. I'm actually reasonably happy with the default firmware that is from June this year. But I'm having an issue where my wireless USB mouse is not recognized. I've actually tried two different mice and neither works. I tested a wired USB mouse that work with no issue. From what I found, it may have something to do with USB and OTG? So my question is, has anybody tried a standard old USB wireless mouse with this ROM?
Hey guys..
To help others out ..
(Q-Box Amlogic S905 2/16 GB 2.4/5 GHZ WI-FI Optical, 2xUSB2, SD Card, AV Out) - http://forum.xda-developers.com/andr...hz-wi-t3359807
I also had issues at 97% loading this firmware with a temperature out of range error using setup_v2.0.7.2_build2_12Device
Went to setup_v2.0.5_x86.exe and problem went away.
Installed QBOX 2GB/16GB Superceleron v1.0
Happy with it so far.
Things I have noticed and request.
The remote Kodi key is mapped to gmail for some reason.
The LED button on remote has no effect on turning off or changing annoying bright LED. Would love to be to control this, at least now I can turn off the device properly with remote (no led)
Not to important, would it be possible to add the original boot animation back? https://youtu.be/UOR7JFuDyVM
Its hard for me to fix anything now... since the box its my main box for my girls so... i cant touch it lol until i get another to replace that one!
The kodi key i need to check it when i can, the led button is a no go since its controlled by the original launcher(that sucks hard) and the bootanimation... not from me
Let's try and get you another box ;-) setup a paypal or something. I got mine for around $50
If you got another box, would you continue to update Rom and try to get Marshmallow on there, image it would run smoother.
Good day Every one sorry if I am a the wrong place for this question,
I just both two ott q-box I have tested on 3 tv the two box boot correctly with the new superceleron rom only on one samsung tv, the two other lg and aquos aren't working and what if very weerd I am using the same cable and the same ott q-box the box start booting and stop at the green screen sometime it is going further but eventualy stop and black screen but signal still on the input since tv isn't switching to no signal any idears ?
regards
Hi there! First of all I appreciate Your hard work, and I really love this ROM. It's awsome!
As I am new to (xbmc) Kodi and android box, do not have much experience.
Most of the movies play smooth and clear, but some of the 1080p .x264 mkv files played stuttering and freezes, but no lag at sound.
What I've tried already: turned off amcodec, mediacodec; turned display refresh rate to 'always'
Sometimes all 4 cores work nearly at 80-95% as i see in kodi hardver section.
Do you have any idea, how to solve this problem or are there any limitation on full hd movies that i no need to try to play?
Thanks for any suggestion or help.
There are currently 3436 users online. 0 members and 3436 guests.
