1. What resolution does YouTube run at on the stock rom and if I update the YouTube app on your rom does that get rid of 1080p playback?
2. How do I know what resolution the video plays at. On my Himedia Q10 pro I can set the quality using the YouTube app but I cannot see the change resolution setting on your rom or the stock rom.
3. Is there just one mainstream YouTube app on android or are there different variants\offshoots?
4. If I choose to return to stock firmware I have the 20160610 update files which I assume I can restore via sd card recovery boot. Now the zip contains the 3 files "p200_2G-ota-20160610.zip, recovery.img and factory_update_param.aml" but to do a stock restore using the Burning tool can I use these files or do I need a single .img file of the stock rom? If so can anyone link me to it. Mine came with 20160610.
5. I chose to update the bootloader. Will my device still function If I restore to stock via files and SD recovery boot?
