[ROM] QBOX 2GB/16GB Superceleron v1.0
Hello,
I would like to know if anyone is working on adding the the 4335 wifi-chip into SuperCeleron's Firmware. I also (just like Meltdown) bought another box mainly because of your firmware and was bummed when the wifi was not working. Anything that could help me figure out a way to fix it would be appreciated.
Thank you,
I was looking forward to using this ROM until like many others came across this issue with the new boxes (wifi on board) and remote control. Like many others I contacted Coolead and they gave me a download link for the stock firmware.
I have taken remote and remote1 .conf files from the directory for future use if required.
however as im browsing through the storage/etc files i came across a folder called AP6330 and quite a few other files located in this folder.
I was wondering if i was to re-install your ROM and transfer over these files if everything would work? or is it not this simple. If the Creator of the ROM would like these files i can happily send them over.
Kind Regards
No need i have the files
And no it work work since it tries to load the files from the other fw, this is because it hard coded to the framework.
Some boxes now have a option in the build.prop that you can choose what wifi chip is used on the rom... but this is not used(coded) in 95% of the roms out there!
There are currently 2520 users online. 0 members and 2520 guests.
