[ROM] QBOX 2GB/16GB Superceleron v1.0
Here use this apk (https://download.cnx-software.com/in...i1Qcn0fvGd1VS3) , unpack it and install it on the device execute it, press "Reboot" on the apk and voila is fixed, the app autoexecutes itself every reboot or poweroff.
This is a prahjister apk
Originally posted by superceleron View PostHere use this apk (https://download.cnx-software.com/in...i1Qcn0fvGd1VS3) , unpack it and install it on the device execute it, press "Reboot" on the apk and voila is fixed, the app autoexecutes itself every reboot or poweroff.
This is a prahjister apkPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
GREAT!
Now it works with all my DTS Sources!!!
BIG THANK YOU prahjister !!!
Two Questions:
1. This will work on all S905´s?
2. How do i grant Storage Permission for the APK?
Two Questions:
To give storage permissions. Go into andriod settings. Then apps. then find and click it. Go down to permissions and make sure it has storage permissions on.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View Post
Have to test....So far works on s905 s905x and s912. At least one of each
@superceleron:
Will there be a another version of your little masterpiece? Or will it not be needed until android 6 ?
Last one, can i update all Apps that came with your rom, like netflix/youtube or is the version that you used the only one that really works prblemless?
Ok, Thanks for everything and the quickest response on the internet
one little thing with led, you wrote "Removed the default launcher it have a lot of stability problems, so you will lose the led color change since its the launcher that controls it!":
loseing control of the lightshow aint a big loose, but the function to turn it off with the remote button is a lost....for me. how can i turn the led off, except by opening the box?
(what i maybe gonna do, because off the CPU thermal, i got really good thermal paste and with that the idle temp and full load will go down like 9-12°)
Well... maybe in the update i will make a script for the ppl to execute by the terminal emulator app to disable it!
Or i will make it and post it here before i make the update to the rom.. hmm need to see what to do!
scooter2014 LOL
my donation will sure come!
THIS IS REALLY A GREAT ROM !
and with the https://download.cnx-software.com/in...i1Qcn0fvGd1VS3 (THE FIX for the Passthroughproblem prahjister)
SIMPLY THE BEST FIRMWARE FOR THE Q-Box!
Originally posted by superceleron View PostWell... maybe in the update i will make a script for the ppl to execute by the terminal emulator app to disable it!
scooter2014 LOL
There are currently 1174 users online. 0 members and 1174 guests.
