[ROM] QBOX 2GB/16GB Superceleron v1.0
Originally posted by Padrino75 View PostMan, nicely done, props for buiding your own ROM and sharing...
The thing is, i tried everything, and i can't get the USB Burning tool to recognize the QBox...
I am using Win10, downloaded the USB Burning tool you provided, unchecked the temp, toothpick, USB in inner port, power, and still nothing...
Any help?
Thanks in advance!
http://www.fisier.ro/download?f=7fc4e33a863 , it will install libusb win32 drivers.
try installing these drivers as well
q box drivers.zipAttached FilesLast edited by carianis; 19 July 2016, 07:06.
Stiller thesaurus AML oficial USB Burnett doesn't recognise thesaurus qbox...i am using an USB 3.0 superspeed cable from Logilink, 3m long. Tried on all 4 ports (2×2.0 2x3.0) and still nothing...
Do you recon it might be the cable? Anyway, can someone help on how to flash the custom rom via sd?
Thanks in advance
Originally posted by Padrino75Man, nicely done, props for buiding your own ROM and sharing...
Any help?
Thanks in advance!
EDIT: is as using a USB 3 cable as well.
Sent from my One using Tapatalk
I installed the SuperCeleron img and am very happy ! Thank You for your hard work.
I'd like to ask if anyone has the 'code' for the remote control so I can add it to my receiver. Thanks, !Q box GPU: Mali-450 SuperCeleron 1.0, Android 5.1
CPU Amlogic S905 Octa Core, 2.0GHz, RAM 2G / ROM 16G
MX-10 box, rk3328 chipset, amazon TV app DOES NOT WORK, 4gb/16gb
I tried to install the stock launcher, but it didn't solve anything (remote hotkeys) ex. The button and all the settings hot keys, neither solved changing the led light.
I know you don't care much for the remote, but I think many people do, I only got the default remote, if you come around it, maybe you can take a look to see if it can become working?
There are currently 1675 users online. 0 members and 1675 guests.
