you the man! will definitely try this. will you be able to do something about the led lights being controlled outside the original SunvellWin8Launcher? in case you decide to look into this, maybe this would help:
- as you well said it, leds only work while in home screen on original sunvellwin8launcher
- dmesg in terminal emulator gives the below for the led button on the remote:
<1>[ 328.006310@1] QBled: cmd:0
<1>[ 328.006333@1] QBled: arg:3remote: press ircode = 0x42, (204) (info)
<6>[ 329.341866@0] remote: scancode = 0x00cc,maptable = 0,code:0xbd42fd88
also this (note the bold red that i highlighted)
<1>[ 790.572888@2] QBled: arg:0type=1400 audit(1420071193.720:20): avc: denied { getattr } for pid=4788 comm="ll.win8launcher" path="/dev/qbled_dev" dev="tmpfs" ino=11295 scontext=u:r:untrusted_app:s0 tcontext=u
- the ir code "0x42" is mapped as linux keycode "204" as seen in /system/etc/remote.conf
- the linux keycode 204 is mapped as android keycode "info" as seen in /system/usr/keylayout/Vendor_0001_Product_0001.kl
that's all i've got and that's as far as my knowledge took me. maybe you can uncover more in order to have this led lights controlled independently, should you decide to do so.
thanks for your efforts anyway!
