[ROM] QBOX 2GB/16GB Superceleron v1.0
Absolutely love this ROM.
Installation was easy. Setup was a breeze.
Love the 720 and 1080 working in youtube and the latest youtube Android tv apk even works now in 720 whereas on stock only 1.2.7 works 👌
Only question I have is why won't the x86 version of kodi install? I can't see any reason why it shouldn't.
superceleron 1. i'd like to have the bottom menu toolbar showing after boot and stay there at all time. can you pls tell me how to do that?
2. i have succesfully changed the bootup logo on the stock rom using amlogic customisation tool. i have tried the same with your rom, it worked at first boot after flashing the so customised rom, but it no longer worked after that, on subsequent reboots. i know the bootup logo is there as your own credits, but for the sake of sharing knowledge, would you pls tell me why that is and how to overcome it, i am just curious now!
thank you!
hi
Sory for my poor english... i'm french
Just a question: if i try this update and it is not ok, is there a way to go back with the previous firmware? if that where can i find the previous firmware?
Thanks in advance for your answer and good job for your rom which i hope could repare playstore and netflix. That are only the two thinks that don't work with my box, and also some applications don't want to install by playstore. It says your device is not compatible.
With USB burning tool, we have to let default options (erase flash and erase bootloader checked)?
cdt
Pat
Originally posted by carianis View Postsuperceleron 1. i'd like to have the bottom menu toolbar showing after boot and stay there at all time. can you pls tell me how to do that?
thank you!
About the menu bar, check the build.prop...
The 2ยช one cant help you!
cdt
Pat
Yes i have the stock rom if you need it!
And on this one flix store etc.. work just fine!
On usb burning tool, you can leave the default options or you can disable erase bootloader if you want!
Originally posted by carianis View PostGuest 1. i'd like to have the bottom menu toolbar showing after boot and stay there at all time. can you pls tell me how to do that?
thank you!
As far as your boot animation you should be able to use any animation you want. Just go to system/media and change the bootanimation.zip to anything you want. Just make sure you change permissions to rw- r- r- after.
There are currently 3569 users online. 0 members and 3569 guests.
