There are several Qbox out there now with different wifi chip's, when i made this rom there was only one... and you should never ever flash a rom if you dont have the right stock one for your device!
[ROM] QBOX 2GB/16GB Superceleron v1.0
For you box dunno. since with my rom you dont have wifi it means with this box stock rom its going to be the same...
I need your help ... I have an OTT TV BOX Q-Box 2GB / 16GB Android 5.1 Lollipop TV Quad Core 4K UHD 3D 1000M LAN Bluetooth Dual Band 2.4G / 5G Wifi Kodi 16 pre-installed Add-Ons Fully Loaded Rooted Unlocked Streaming Media Player Led 3 Colors (blue, red, green).
I would like to install your Superceleron ROM. I'm looking for videos to know how to do, I did not find anythingI followed step by step, nothing I got
I have win 10, cable usb AA, usb bournig tools 2.0.7.2 and 1 toothpick. Soft usb bournig tools does not detect the box. It will ask a lot ... can you make a video show how to install your firmware in Q-Box, please ?!
Originally posted by andrepereira94I need your help ... I have an OTT TV BOX Q-Box 2GB / 16GB Android 5.1 Lollipop TV Quad Core 4K UHD 3D 1000M LAN Bluetooth Dual Band 2.4G / 5G Wifi Kodi 16 pre-installed Add-Ons Fully Loaded Rooted Unlocked Streaming Media Player Led 3 Colors (blue, red, green).
Originally posted by Rob2421 View Post
Make sure your wifi chip is compatible with this rom. I updated and my wifi quit working.
Yes, the wi-fi works.
What does not work ... is to turn off the led lights with the remote control. If there's another way turn off, I would like to know.
Thank you.
There are currently 2731 users online. 1 members and 2730 guests.
