esexplorer i mean no supersu app
[ROM] QBOX 2GB/16GB Superceleron v1.0
Hi buka09 ,
this shall help :
https://seo-michael.co.uk/enable-roo...file-explorer/
when you flashed the Rom from here you must have SuperSu installed .
I have the same Box with same Rom , i know it is rooted .
greetings / gefattern
Hi buka09 ,
first did you solved the root & copy Problem ???
with Wifi , we must know what WifiChip your Box has ???
what exactly happens when you want to turn it on ???
the Button becomes not "blue" / no Network found ???
please describe what happens .
Ever did a Factory reset / Settings ??? remember this
will wipe all your Data , so Backup .
have a nice Day
gefattern
have a nice Day
gefattern
sorry for late answer. I flashed as first superceleron rom wifi not working, that i flashed original rom with andriod 6 buz it not working too. remote.conf i replace its working with your tutorial, thanks but its not working with remote. i buyed mini keyboard with trackpoint, but it is not problem. Very important for me is, that wifi not working. i make a fotos of my qbox, would you like to help.me which wifi chip i have?
maybe helping to flash android 5.1. stock rom?
thanks you
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by gefattern View PostHi fdeutsch ,
i do not think it supports ATV Apps / it is not a ATV Rom / for Netflix HD you need Widevine .
Do have this Box ??? if not better stay away , there are better once .
good luck / gefattern
Originally posted by buka09 View Post
Hi gefattern,
thanks you
please read what stands on the small Chip (Pic.No.1) right of CPU (Heatsink) , under the HQST chip 1620H ,
u can see a small antler on it , this must be the Chip u search for . good luck / report / gefattern
Hi buka09 ,
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hi buka09 ,
sorry my Info was not correct , but you found it by yourself , yes this looks like
your WifiChip , but strange why you not have the AP6330 ??? like we all have .
I looked once more the Link of your Box , your Remote is different to the one
we all have . If you really bought it by the Link you posted in #361 .
How long do you have this Box now ???
I am not sure if there is a CustomRom for S905 2/16 with Wifichip KM633521.
In Post #371 you ask for help with flashing StockRom , do you have the right
Stockrom ??? .
A small cheap WifiDongle is a alternative Solution for your Problem , i think it
works , but never self tested . nice Day / please answer / gefattern
There are currently 2468 users online. 0 members and 2468 guests.
