[ROM] QBOX 2GB/16GB Superceleron v1.0
Hey Super!
Thanks for the awesome ROM. Definitely saved my ass from having to deal with crappy preinstalled nonsense!
i was wondering if anyone had had any luck regarding controllers. I've tried multiple different controllers and couldn't get any to connect (Xbone with pc USB dongle, PS4 Bluetooth, 3rd party x360 USB, PS3 usb).
Without a controller, I can't use retroarch on my box. Which is a damn shame.
If anyone has controller suggestions that work, I'm all ears!
thanks again!
Google:usb/bt joystick center 2015
Or https://m.downloadatoz.com/usb-bt-jo...ee.usbjoyfree/
I have bluetooth csr4.0 usb dongle and ps3 controller,work perfect(test on arm and x86 platform).
Have fun!
Originally posted by bigd1979666 View PostHey guys, is this for the Sunvell Q-BOX (s905)?
Originally posted by XeCuTioNR View PostDoes anyone have a working set remote.conf files for the QBOX? I lost functionality to my remote after this update. Thanks
Hello. After flash is my remote not working. I foundent a remote zip in this tree but i dont know how to transfer this on the qbox? Remote not working, per usb its not recognized as sd card, adb not working, because i cannot setting this (remote not working). Please tell me how i can replace remote.conf on my qbox? Thanks very much. Sorry for my bad english
Originally posted by gefattern View PostHi buka09 ,
first you need another AirMouse/Mouse or BT Mouse to act on the Device .
second you need root , then you can replace the File and hopefully use your
Remote if all permissions and keyvalues are good .
greetings gefattern
thanks for your answer. I tried to connect usb mouse and it worked! Thanks. But if i xopy remote.conf to system i got an error that the system read only access have. The next problem what i have, is that wifi not working too.
Have you idea how i can solved it?
thanks
Hi buka09 ,
you must give the Fileexplorer "Root rights" , what kind of Explorer do you use ???
ESExplorer ??? (is the App SuperSu installed on your Box???)
Wifi does not work becauce this is not the correct Rom for your Box , we need the
WifiChip Typ/Nr. , do you have the 2/16GB Version ??? QBox is not QBox because
different Producers use different Chip components same with other ChinaBoxes .
hope it helps / greetings / gefattern
There are currently 2486 users online. 0 members and 2486 guests.
