[ROM] QBOX 2GB/16GB Superceleron v1.0
This is a wild shot in the dark but is there anyway to update the Qbox with a Mac? I understand I can use a virtual machine but is there any tool similar to the USB loader for the MacOS? Got one of these boxes and can't update my Kodi through Google Play and see updating firmware may help. Terribly frustrating!
Originally posted by gefattern View PostHi ,
under the Box under the Rubberband in the Corners are 4 screws ..
good luck
gefattern
I checked and I don't have the "common" wifi module in my box, so all the firmware that I install (0610, 0614, 0812 and 1012, and Superceleron FW) do not support the BCM4335 module, and unfortunately Superceleron has moved on and has stopped updating his rom. I installed the Superceleron firmware for the sleep/on/off function which worked, but I lost my wifi. I just want to get back to where I was at in the first place now because I need wifi. I'm on 0812 now, works ok, no wifi though.
So if anyone knows where I can get the Q-Box 2GB + 16Gb Android 5.1 with support for BCM4335 let me know. Many thanks.
Originally posted by Meltdown View PostTrebor, would you recognise the wifi chip on this new one at all? I'm wodnering if it would be possible to take the WIFI drivers for this chip - if it's common enough, out of some firmware and put it into celeron via the amlogic customisation tool?
Originally posted by gefattern View PostHi ChockyMonkey ,
look here and ask , maybe one of the uploaded Roms will work :
http://freaktab.com/forum/tv-player-...firmware/page2
Where did you buy it and what was the latest Stock 5.1/6.0 ???
good luck
gefattern
It's working well with the 0610 or 0614 firmware, google play store, services, kodi 17.1 but no wifi just ethernet.Last edited by ChockyMonkey; 07 May 2017, 06:29.
This is maybe a long shot but i gave this box(with this ROM) to my brother, but for some reason on his TV (sony bravia kdl-32ex301) screen turns pink/green.i have checked on other threads on freaktab,and I've find out it's due to the RGB.people have reported that in settings that if force RGB is used,that fixed the problem but on this ROM there is no setting,has anyone have a zip file so I can install the fix setting or is there something I've missed in the settings? hope someone can help thanks.here is screenshot of the force RGB setting I need .You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
But no wifi function
Does not turn on
I tried 2 times to flasshare the firmware but nothing. Always the same defect
Does not turn on wifi
Originally posted by maxxxy View Post
Thanks I got to put the firmware
Does not turn on
There are currently 2514 users online. 0 members and 2514 guests.
