[ROM] QBOX 2GB/16GB Superceleron v1.0
Originally posted by ScottishChris View PostHi guys, just bought the qbox and having slight problems. Playstore,kodi etc keeps giving me not responding messages and its pretty annoying. If i install this ROM would it possibly fix these problems? Also the box flickers every 20-30 mins. Thanks guys
Originally posted by gefattern View PostHi to all ,
here are a Picture of the FanMod made it with USB , like my UT3 :
but LibreElec is still not on my QBox.
Yes that all work ok in this rom, now the problem looks like theirs another QBox out there with a different wifi chip...
Originally posted by maceypI was looking forward to using this ROM until like many others came across this issue with the new boxes (wifi on board) and remote control. Like many others I contacted Coolead and they gave me a download link for the stock firmware.
I have taken remote and remote1 .conf files from the directory for future use if required.
however as im browsing through the storage/etc files i came across a folder called AP6330 and quite a few other files located in this folder.
I was wondering if i was to re-install your ROM and transfer over these files if everything would work? or is it not this simple. If the Creator of the ROM would like these files i can happily send them over.
Kind Regards
There are currently 2515 users online. 0 members and 2515 guests.
