[ROM] QBOX 2GB/16GB Superceleron v1.0
As far as i'm aware i've tried the sd card method but its seems very firmware specific and very sd card maker specific.
It would be very helpful to get all the specific files and apps in one place and a step by step how to. TBH the files I'm talking about are firmware, stock rom, best usb burn tool, best sd card maker, proper video showing how to deal with this shit. I've been flashing roms to phones for 8 yrs without a single brick wtf is this??
this is the world of Chinese tv boxes unfortunately!
here is a good explanation, is in portuguese but i think it easy to understand it even have a video.. this is for the sdcard method!
Originally posted by Meltdown
Thanks for the quick response. It's crazy - the firmware they supplier sent me, wifi doesnt work on either. They claim it;s newest. Dated 26 Oct but definitely wifi does not work.
I'll try Sunvell directly.
Sent from my Redmi Note 2 using Tapatalk
Hi Superceleron,
Can I boot Your firmware from sd like i did with my old rk3188 and rk3288 device ? See http://freaktab.com/forum/tv-player-...y-to-dual-boot (I noticed You was involved in that thread).
EDIT:
I see this thread related to booting openelec with modified uboot for tronsmart (http://freaktab.com/forum/tv-player-...thod-and-files). Do You think is usable with qbox and Your android image ?
Originally posted by bebop80 View PostI was wondering...as this is an amazing rom and as it is based on android 5.1.1 is the creator thinking to update it basing it on the android 6? :-) :-) :-) Sorry for the stupid question but why not to ask? :-)
EDIT:
I have the latets firmware superseleron with the correct wifi drivers but ive been given it in SD Format (I think the facotry firmware is pretty poor on these boxes and only really bought another one because of your firmware to be fair) is it possible to get the wifi drivers out of this system.new.dat file and into your *.img rom?
Ok, quick update,
I've managed to pull the broadcom wifi drivers out of system.dat.new on sd card zip firmware sunvell gave me and have tested it in a seperate img image I found from an earlier manufacturer firmware release.
Hopefully I'll be able to get a rom up here for those that come to this thread with the broadcom wifi issue.
superceleron, can I ask - would you be able to share how to change the default launcher at firmware level? Their standard one is absolutely garbage.
Thank you
the usb driver is in the "USB Burning Tool" it should install it when you install the app!
Here is the tool: https://mega.nz/#!U4UTBbjI!lMc7Co-dz...RWYRYtK7-wg0nk
There are currently 1688 users online. 1 members and 1687 guests.
