SCISHION V88 RK3229 4K Android 5.1 KODI TV BOX 1G/8G WIFI LAN Dolby DTS
Originally posted by zenix View PostIf you want MULTITASKING, edit built.prop in system/ and change "ro.config.low_ram=true" to "ro.config.low-ram=false"
Everything after, works very good!
Originally posted by aian0306 View Post
that's whatbi had in mind- replace and delete system apps too- for smoother performance- mine isn't auto updating after reboot.. update.IMG is placed in SD card- I tried rebooting.. then after system started .. inserted the SD card.. waiting for motif to update.. but nothing is showing up--
Go to system/about/wireless update then click on upright 3 dots and choose local updates. Find the update.img and try to update!
already tried that too. but the wireless update only recognize zip file. and also tried renaming it and ziping it.. all goes to OTA failed footer is wrong installation aborted- jeez.. I'm really tired with this lol.. still thinking other ways
Try through twrp. Insert a toothpick in av hole. Inside is the reset button. Hold pressing the toothpick and reboot. Your system must be now in twrp. With remote choose update ( if there is any such option) and choose your img or zip
wipe cache partition
adb
bootloader power off
I already tried my luck with the recovery but seems to be well locked
no such option. just clear data/factory reset
adb
Make a last try. Try this first http://4pda.ru/forum/index.php?showt...#entry56364554 , then update
I'm trying to get root access that's why I want to flash update.. its impossible to flash twrp when my box is not rooted.. thanks bro.. I really appreciated the help.. I'm hopeless haha
What is your version of firmware? Because maby it s already rooted. Just update superuser binary and reboot. If you cannot find SU, try to jnstall it from playstore
Originally posted by techclown View PostSo I've looked and may of missed, but I need two things if someone can help,
1 can you root v88 and how?
2 I cannot change the home launcher without it asking me every time if I want to set it as my default
If I can get these sorted I'd really like this box
There are currently 2628 users online. 5 members and 2623 guests.
