That said, the tip about editing the build.prop also works to ensure the box still multitasks but use with care as a poorly edited build.prop will brick your device.
SCISHION V88 RK3229 4K Android 5.1 KODI TV BOX 1G/8G WIFI LAN Dolby DTS
Then you have to go the long route... that means you need the Rockchip Tool, Rockchip batch driver software, and a USB A to USB A cable.
Originally posted by davedeluria View PostThen you have to go the long route... that means you need the Rockchip Tool, Rockchip batch driver software, and a USB A to USB A cable.
i need to fix it so that Netflix will play without sound delay
Here's a video how it's done.
Our 2018 #BlackFriday Super Deals have arrived! Everything you need starting at $0.99: http://bit.ly/2QUwDP1 Check out all the available coupons and get a di...
I would NOT flash it just for a Netflix problem. That's a totally different issue that re-flashing will not fix. If there's no sound sync delays in other programs then it's the Netflix app you need to fix, not the entire box.
Originally posted by omer menashe View Post
i can't find the .img there
when i used the zip file you linked or changed the .img to .zip that's the screen i get.........
I would suggest leaving the file as a zip. That is usually what Rockchip OTA update files are.
Good luck.
i read that it works better in 4.4.4.
Lollipop has sync problems for lots of apps and Marshmallow also fix it but then brake Google Play and remove pass-through support.
The only way to have Netflix in sync on Scishion is to use KitKat firmware I'm afraid.
Hi, I just joined because I have this tv box model. I have a problem, I remained fixed red light and does not want to turn on either the remote control or even removing and replacing the power supply. I tried to do the flash but the device is not detected by the PC. I have to short the pins 29 and 30?
Sorry for my English but with google translate.
UPDATE 12/03/2017
I managed to make the flash and gave no errors.
But the device remains with steady red light.
I noticed the device that a "BX6L" transistors broke.
Does anyone have any idea where to buy it online?
I tried it on aliexpress but there is.You may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosLast edited by bgiovanni; 03-12-2017, 11:53.
There are currently 2606 users online. 6 members and 2600 guests.
