SCISHION V88 RK3229 4K Android 5.1 KODI TV BOX 1G/8G WIFI LAN Dolby DTS
    How have you installed update?
      n583846 SCISHION, V88 Android 5.1 RK3229, quad core Up to 1.5GHz GPU Mali-400MP OpenGL ES 2.0 DDRIII 1GB Nand Flash 8GB TF CARD Support 1~32GB Wifi Connectivity
        I have this box i installed leanback launcher but cant seem to access the settings app or recommendations i have no idea why is it related to the fact that it is a rochip soc?
          I bought the scishion v88 from gearbest 2 weeks ago, and i was not happy with it the kernel was defined as 720p even if it can support 1080p so videos on youtube was only suported as maximum 720p,even if the hdmi port is setup to 1080p i gues youtube checks if the 1080 is real or upscaled from 720p , which on this tv box it was, so yeah i can confirme that 1080p resolution is realy 720p upscaled. But i found a fix for that its a app called nomone resolution changer, you can find it on google app store. It changes the kernel registry so that 1080 resolution is real 1080 not 720. In this app you have to manualy input the resolution 1920x1080 and change the dpi from 160 to 240 so that it fills the screen. So now youtube plays 1080p video very nice even if there is some minor flicker once a minute or two. But it plays verry well. I must mention that the device has to be rooted to implement this .Please do not instal the gearbest 6.0 rom because it is not rooted and it does not work well. I was able to do that on a custom rom, here is the link; https://yadi.sk/d/OG-OrwXJ33kNiU
            Originally posted by jmmwifi View Post
            Plus one here!! Any sollution yet
            Enviado do meu ASUS_Z00AD através de Tapatalk
            I saw this solution somewhere but can't remember where. Anyway, it solved the Netflix audio out of sync problem for me. Go to Settings -> Display -> HDMI -> change the setting to a 24hz frequency.
            Some others say it didn't work for them as they did not get a 24 hz option - perhaps their TVs don't support that?
              I dont have anymore this box but i think Netflix problem solved by downgrading firmware to kitkat
                Hi all. New here and to this V88. As always with cheap Android devices, some work to be done. I have the RGB problem and my screen goes bad every so often, seems to be about 5 minutes after starting and then about after an hour, then fixes itself in about 1 minute. Or I can cycle the HDMI inputs with the remote quicky to fix. Not too bad. Kodi 17.0 working well, waiting to try 17.1 and maybe some Acestreams in Plex. Did an app clear out with RootAppDelete (phone, calendar, most Google things). I have no account on this, getting my apps from apkpure. This setup made my old MK802 work well for many years.
                Now, at http://4pda.ru/forum/index.php?showtopic=763997 there is a UGOOS UT6 v1.11 firmware available which works for V88, though it needs a WiFi patch. What is interesting for me is that there is now a UGOOS UT6 v1.20 firmware that HAS AN RGB FORCE OPTION! I don't want to destroy my new V88 just yet, though I have done TWRP, firmwares etc. before on other devices, but I will try this some time if nobody else does it.
                  i have that box too. but stucks on Android logo... i try factory reset and cache reset. i dont have a USBA/USBA cable. can i reflash the firmware just in recovery mode ? i ever get the footer failed error, can anyone help me ?
                    My box has finally a Full HD resolution. Thank you so much for the great tip. There is now a new firmware on Gearbest (rk3229_6.0_MX4N_SSV6051p_zhongx_20170405_v009_Spe ctek) and I can confirm it is rooted.
                    Thanks again and best regards,
                    Hartmut
                      Hartmut
                      Do you have a link for that? Google doesn't find it. Don't suppose it has an RGB force option...
                        I make an android TV rom with rk3229_6.0_MX4N_SSV6051p_zhongx_20170405_v009_Spec tek
                        Go here:
                          You can found it here: http://www.gearbest.com/tv-box-mini-pc/pp_401684.html
                          Scroll down till you see "Click it to download the newest firmware of Android 6.0 version" click on it and your download will start automatically.
                            Anyone that can tell me if Netflix is working ok and if sound is synced in v009? Also can you install and update apps from gplay? becouse in v007 you can not, you must install apks from other sites.
                              Netflix working ok with that rom, you must install apk from another sites. For me it´s ok, nothing to complaint now.
                                Thank you, this means i'll stay with v007 as it doesn't seem to have any advantage jumping to v009
