New Firmware: Sunvell T95Z Plus TV Box Amlogic S912 Octa Core:
Hello Eveyone I' m a new member from Spain. I' m looking for some help regarding my new TV Box T95Z plus 3 GB Ram/32 Rom Voltar Brand purchased in Alli Express from Shenzhen Yojia Technology Co., Ltd. selle. From the first time I have had several issues with this device from so they recommend me to update/upgrade via SD card downloading a new firmware available. T95Zplus-v33 containing the following files:
factory_update_param.aml 2017/3/3 AML 1KB
q200_9377-ota-20170303.zip. 2017/3/3 WinRAR ZIP 616,594 KB
recovery.img 2017/3/3 10,738 KB
And my question is this. Do I have to unzip any firmware file before copying them to TF card root? I do not exactly the steps to copy the files to micro SD card succesfully via PC. Any advice you may give will be helpfull for me. Thanks so much in advance.!
Originally posted by jazmie View Postmine is rooted firmware...anybody got unrooted firmware for t95z plus?....cos some apps i cant run on rooted version...i got try to unroot used supersu etc...but not working
Hi Killer7, i have had same problem, se my solution:
Hi i have had wifi problems se #412. I have a KM63350209 chipset and sometimes it´s working with the Superceleron V1 Final ROM. Thank you. You can see with the terminal emulator in /system/etc/wifi wich chipset the ROM supports. Since my box works very erratic i found a new solution. I saw in /system/lib/ modules that supported other wifi dongles. I had a TP-LINK TL-WN725N and i loaded the driver with this command using the terminal emulator:
su
cd /system/lib
insmod 8188eu.ko
if you have to remove the module then use "rmmod 8188eu.ko"
It works for me. And yes it´s only 2.4 ghz, but its wifi... and i get around 60mbit.
There are more drivers...
Originally posted by MartBiOs2k View Post
Hello,
I just saw that there is a new release ''again'' for the t95z Plus a 3GB RAM and 32GB flash. that what explaion you special build.
Now you need to search and see if your internal hardware match oldest hardware. if yes then you can use same build that posting here and there.
The newest hardware that identify the build you need to use is the WIFI chip. recent version of the t95Z Plus sold with a 9377 Qualcom and bluetooth chip.
I got mine as the one you describe here, 3gb/32gb, 9377 chip, it comes with build T5ZP0064, I have the full img file available,
Can you do your magic on this one ????
Thank you.
Originally posted by amhonra View Post
Hello MartBiOs2k
Thank you.
I am facing a big problem in chinese input by remote.
The firmware is poor compatible with any Traditional Chinese input app.
Does any body where to find the newest firmware might work better?
I have T95Z Plus with 3/32 GB and Wifi LTM8830/qca9377. Is there any Rom firmware with really working Bluetooth , I am using v.64 and Bluetooth works with any audio device with periodical loosing connection and then reconnection again, something like one time per 5-10 minutes. Originally I had v.63 firmware but I lost it during flashing with v.64. Is there any solution for this?
Hi all, I've been using nexbox a1 16/05 firmware on my T95Z 2/16 Ap6330 without any issues for a couple of months but today I thought I would try the mk22 7.1 firmware from may. In usb burning tool 2.0.8 I get Mac 0 even though I've changed the ether.ini thingy & with bootcard maker nothing changes booting to recovery & with pin in av hole I get green droid with an x in a red circle. Has anyone run the mk22 7.1 on this box, how is it & how did you install it? Any help appreciated. Is it covered in another thread? cos I couldn't find anything
Originally posted by Boneo View PostHi all, I've been using nexbox a1 16/05 firmware on my T95Z 2/16 Ap6330 without any issues for a couple of months but today I thought I would try the mk22 7.1 firmware from may. In usb burning tool 2.0.8 I get Mac 0 even though I've changed the ether.ini thingy & with bootcard maker nothing changes booting to recovery & with pin in av hole I get green droid with an x in a red circle. Has anyone run the mk22 7.1 on this box, how is it & how did you install it? Any help appreciated. Is it covered in another thread? cos I couldn't find anything
Originally posted by Boneo View PostThanks jit18 but when I import firmware it doesn't appear at the bottom of usb tool. Tried 2 different copies of firmware on both Windows 10 & 7. Any ideas? Thnx
Can you become a bit more specific...
Does it happen only with the ubt from the link i send you?
Did you try to load other firmware files?
Could you load the firmware with your version of ubt?
If so just copy the complete license folder from the link i send you to the ubt you previously used...
There are currently 2286 users online. 1 members and 2285 guests.
