New Firmware: Sunvell T95Z Plus TV Box Amlogic S912 Octa Core:
    I'm testing the new release now, i'll will make a custom from this source
      Great!!! I will wait for it! Mean while no change log on this new version... at least i don't find it!
        well the RGB fix on display is now available, I remember a user here need it to fix his Philips tv
        i'm not sure if it have the dark video fix.
        other then that I don't see anything added, maybe less useless app
          which wifi chip does this new rom work with?
            Kodi doesn't seem dark anymore... Maybe they fix that!
              I just post my new release of the latest firmware, i think this is the best release to date. I fix some performance and stability of the wifi
                Nice. I have just bought the t95z and installed superceleron rom. Do you think it's worth it to change to the one you've just made? What's the difference between them? Thanks MartBiOs2k.
                  Hi, As know, the SuperCeleron firmware does not support the New version hardware of the t95z plus that have a LMT8830 qac_9377 Wifi chip.
                  So, if your wifi work with superceleron rom, stay with it!! or you will end up loosing wifi fonctionnality.
                    l33tlinuxh4x0r
                    It's for the newest Wifi chip version 9377
                      Yeah but mine is connected through ethernet cable. Don't really care about wifi. Is there any major difference between yours and Superceleron one? I think SC rom its from December last year. Maybe there are some new fixes on the new rom that you modified. Did you notice some improvements? Thanks again MartBiOs2k.
                        Ok so if you recently ordered your box then you probably have the box with 9377 Wifi chip, if you open your box (4 screws behind the rubber feets) then you should have exactly as my pictures in first post.
                        if yes then I suggest you to flash the newer source T5ZP0033 (my custom firmware if you want is from same source + some fixes). in this version everything is fixed (dark video and RGB output option)
                        You get kodi + addon integration
                        Try it i'm sure you will like it, if not reflash SC rom and you are back to what you know.
                        http://freaktab.com/forum/tv-player-...hip#post627174
                          Thanks for the info MartBiOs2k. My box is the first version. I have wifi with SC rom. So it must be the first one. I will try yours anyway. I will post some feedback. Thanks.
                            Hello Trebor, got link off your post for T95Z plus new firmware. I know it has to be converted before you can put it on a usb or sd card, not sure of tools to convert with. Thank you very much.
                            GMX
                              GMX
                              Hello,
                              you have some tutorial on internet
                              http://androidpcreview.com/how-to-us...firmware/3749/
                              and you have to make you own USB A to USB A cable or buy it.
                              http://www.instructables.com/id/Male...o-A-USB-Cable/
                              welcome to flashing world
                                Hello everyone, I want to ask something..
                                Right now, my firmware version is T5ZP30031, Is that the lates firmware?
                                I'm using the T95Z Plus 3GB DDR3 ROM, the only problem I have is the dark video kodl screen
                                At the moment I'm using Screen adjuster. I wonder if the newest firmware has fixed this?
                                Thanks alot
                                *sorry for my bad english*
