EDIT: as for your problem with the wifi, it is probably something in the init files.
New Firmware: Sunvell T95Z Plus TV Box Amlogic S912 Octa Core:
Originally posted by l33tlinuxh4x0r View Post
Yeah, It is just the "Downloaded Packages" that reinstall. System packages do not. And you are right that play store v1.0 doesn't cause it but it is needed to use the play store.
I noticed for some reason, if you're using the default launcher, only the Play Store v1.0 shows in the app tray. The legit version Play Store does not show. So if you disable Play Store v1.0, you won't see any Play Store app in app tray. But in Nova launcher you see both Play Store apps in the apps tray. So if you disable the Play Store v1.0 app, you'll still have the legit one showing. Both of them work but I disabled Play Store v1.0.
Originally posted by xmanh29 View PostHey Guys, I'm new here so I might not be posting this in the right place... In some videos the image is very dark, as this happened to any of you? How can I solve it.
Thank you
What box do you have? It seems to be a common problem with a lot of the boxes based on the s912. However I do not have this issue so I can't help much. I have a Sunvell T95Z running firmware 0007 if that helps.
Do you know what wifi chip that you have? I haven't seen that firmware version yet.
I'm not home now.
Originally posted by jseeley View Postl33tlinuxh4x0r: You mean two versions of firmware or two versions of something else?
xmanh29: What apps are you using where the picture is dark when watching videos? What about using other apps with videos? Youtube?
I just installed T95Z PLUS_S912_06012017_AndroidTVBox.eu.zip (20170102 – build T5ZP0010) firmware to my t95z plus box.
Only problem is that blinking green blue led string. I cant shut it down using remote control. Nothing happens when I push LED button.
Do you have the same problems? Can I shut it down somehow?Last edited by juffe; 01 February 2017, 20:36.
There seems to be many versions of the firmware... However there are at least 2 revisions of the board itself. Some (most) have AP6330 chipset and others have LTM8800 chipset. People are having more problems with the LTM8800 version but that is probably firmware related. Also there is no way to know before you purchase which chipset you are going to get.
Ahh. OK. Somewhere I read that the one with the LTM8800 has Wifi issues? I wonder if the LTM8800 chipset has current firmware of T5ZP0009 and T5ZP0010 while the AP6330 chipset has a latest of T5ZP0007? Or the other way around?
There are currently 2346 users online. 1 members and 2345 guests.
