New Firmware: Sunvell T95Z Plus TV Box Amlogic S912 Octa Core:
Hello!
I owned a T95Z Plus and plan to integrate a USB-Touchscreen driver for my Packard Bell 23" touch Monitor.
It is recognized (checked with lsusb) as Vendor: 0408, Product 3000 but is not working. I know that from many boxes - I only found one box, where it worked "out of the box" and one, where it works after unplugging and replugging the USB connector. Making an .idc file did not help.
So I think, I have to comile a new kernel, right? As I read, I need a SDK (or Kernel source) for that, right? Can I extract it from the Firmware mentioned above?
Or is there somebody out there, who can help me?
Thanks a lot!
EDIT: By the way: How can I check, if my "T95Z Plus" is compatible to the Firmware above? The manufacturer is "AKASO". But the device looks the same: https://www.amazon.de/gp/product/B01M7TZ46L
Originally posted by Teo-76 View PostI installed the usb principle T5ZP0006 was ... progress bar went through ... but the version has not changed afterwards. T5ZP0004 left. The T5ZP0007 itself was downloaded and wanted to upgrade.
I don't know why you are going to the usb principle, whereas T95Z Plus firmware can be updated OTA .
Thanks a lot!
Sorry I can only answer the last sentence of your question. AFAIK "AKASO" is not the manufacturer of this box, it just only a distributor who purchased bulky orders from China and advertises their name.
Many of those names but always carrying the model "T95Z Plus" are the same, so therefore your box is compatible with the firmware stated above, as soon as your box has the "T95Z Plus" model name.
Originally posted by displaylou View PostIt also happened to me twice when I am updating into T5ZP0007, when I tried the third time I was able to removed the external portable drive from it, and viola! the T5ZP0007 update was successful. Make sure that no usb drive connected to the usb port, then try it again.
OK, I can see the 0007 update in the OTA system, and it downloads OK, but at the point of me clicking "Update Now" all I get is a "Reboot..." message and it sits there. Left it for ages. No changes. Any ideas? Where does it download the build too? Is is possible to grab that and install from recovery mode? If not, anyone got a download link for the file to install it manually? Very weird. I've unplugged my USB HDD and rebooted, as someone else suggested, but it's still the same. Very weird/annoying!You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by displaylou View PostTry to clean first the cache of the system then unplug the box from the outlet then try it again. Let's see if this works.
There are currently 1659 users online. 2 members and 1657 guests.
