i get no Logo, tryed lot of times ......
In the end I copied the files to a micro-SD card and installed it from recovery mode. For those interested:
a) copy the .zip file from the zip folder in the download to a micro SD card (or USB stick)
b) power the T95Z down
c) remove the power cable
d) GENTLY push a pin/cocktail stick into the AV socket and feel for a "click" (the reset switch is hidden behind it!)
e) insert the power while still holing the reset switch down
f) once logo is show, remove the pin
Now i want to flash the box with Amlogic USB Burning Tool , i need the image for the box ..
Ok folks, i manage to flash the T5ZP0010 !!! After Bricking my device and testing with sd card and usb stick i have no success . The above to do was not working for me.
I decided to Use Amlogic USB burning Tool , you only need one file from the T95Z PLUS_S912_06012017_AndroidTVBox.eu.zip. It is the aml_upgrade_package.img .
You can all read on this side http://androidpcreview.com/how-to-us...firmware/3749/
if is not allowed to post the link, delete it ..................
You also need an Usb cabel Male to male !!!
