possible newer firmware for H96 PRO PLUS / H96 PRO+
    HERES THE LINK
    Hoy os traemos (gracias iker) un firmware fechado el 07-11-2016 para el TV-Box H96 PRO+ que incluye el SoC Amlogic S912 Octa Core. Este modelo incluye 3GB de RAM, 32GB almacenamiento eMMc, wifi ac y Bluetooth 4.0. En cuanto a conectividad vemos que también incluye un lector de tarjetas microSD, un puerto HDMI 2.0a, conector Ethernet Gigabit, jack analogico A/V, salida de audio SPDIF y 2 puertos
    heres another one..not sure which one is the newer one
    Hoy os dejamos para descargar un firmware valido para el TV-Box con Android 6.0 H96 PRO que incluye el nuevo SoC Amlogic S912 que monta ocho procesadores ARM Cortex-A53 y una potente GPU Mali-T820MP3. Este modelo dispone de 3GB de RAM, 16GB almacenamiento eMMc, wifi ac de doble banda y conector de red Gigabit entre otros. El firmware esta fechado el 17-11-2016 y no incluye lista de cambios. El
      heres another one..tho I think its been custom modified
      https://drive.google.com/file/d/0BzX...laOURhU0k/view
      scroll down to securi's post
        Thanks for the links!
        Originally posted by gogeta View Post
        I've got an Alfawise H96 Pro+, might give this a try this week.
        Newest: aml_s912_q9377-H96PRO(3+16_kodi17.0)_mac-20161215.zip [seems to be for Pro vs Pro Plus, not 100% sure)
        Older: aml_s912_q9377-H96PROPLUS(3+32_kodi16.1)_mac-20161107.rar [Pro Plus}
        Oldest: h96pro-OK 20160918 [Pro]
          Hi guys, I have a Beelink GT1, its a good option to change this box for a H96 Pro Plus octa core 32GB 3GB S912, or the performance of both boxes's it's similar ?
          Happy New Year.
            Happy 2017 2 all --
            is there a guide on how we flash this (twrp et.al.)? I'm a complete noob
              Happy New Year.
              Happy New Year!
              I also have Alfawise S92 (Same/similar to Beelink GT1 hardware I believe). They run similar but its nice to have the extra 1GB RAM and also 2 extra USB ports (you have to cut out holes yourself though). Launcher is nicer on H96 Pro+ but that is just software.
                Happy New year !
                what is the different between pro vs pro + ? any custom rom for pro + yet ?
                Cheers
                  Hi guys, my box tv pro h96, it presents the following error:
                  [0x30201004]UBOOT/Disk initialize/Send command/Error result
                  I ended up doing the FActory Reset through recovery and it looks like it erased his Emmc memory.
                  Anyone know how to proceed:
                  I've tried usb burning tool, amlogic burn card maker and nothing.
                  It freezes at 7%. I lost my box?
                    pro+ has 3 GB of ram 32gb storage
                      Hi Guys
                      Thanks a lot for the tips.
                      Take care!! :-)
                        Newer firmware for Pro Plus has been posted here: http://4pda.ru/forum/index.php?showt...ost&p=56722287
                        Download link: https://drive.google.com/file/d/0B9H...ZONEtqTnM/view
                          There are quite a few firmwares out for pro plus not sure which is the correct
                            You will want to check the file name, for Pro Plus it will have : aml_s912_q9377_H96Pro+(3+32_kodiVERSION)-date_mac.zip or .img
                            for just Pro it will be aml_s912_q9377_H96Pro(3+16_kodiVERSION)-date_mac.zip or .img
                            So if you want latest Pro Plus: https://drive.google.com/file/d/0B9H...ZONEtqTnM/view
                            I have also posted in the other thread:
                            Originally posted by lyricidal View Post
                            I have repacked the firmware above minus the pre-install files.
                            Here is the list of what they were:
                            facebook.apk
                            GoLive2.0-TV-2.5.0.4-CANZONE-release.apk
                            kodi-17.0-Krypton_beta7-armeabi-v7a.apk
                            mobdro.apk
                            netflix.apk
                            TeamViewerQS.apk
                            TeamViewerQSAddon.apk
                            twitter.apk
                            wk_signed.apk
                            youtube.apk
                            Left it without a Kodi version so you can decide if you want Kodi 16/17 or FTMC or SPMC.
                            Mega download link: https://mega.nz/#!GIckza7A!jsnnqPhCa...6QY2hqwaWR1IVM
                            Credit to securi at 4pda.ru. From what I can read it includes mod TWRP recovery 3.0.2-0 and is for H96 the Pro + 3Gb / 32Gb (Platform q9377). 6330 devices will not have working wifi or BT.
                            Try at your own risk but I have just repacked it for a clean install. Repacked using Amlogic Customization Tool v2.0.8. Went from 977MB to 740MB in img size.
                              Thnx for the quick response. I will try this fireware. Did you tested this? Is this a stable
