possible newer firmware for H96 PRO PLUS / H96 PRO+
Originally posted by Shimon View Post
It seems tomtop sends out faulty wifi specimens or quality control is non-existent over there - please check if the box remains stable running off of wired LAN. That's exactly what happened to me and I managed to pinpoint the defect to faulty wifi as no firmware version made any difference.
Originally posted by scooter2014 View Post
Try the Tanix T8 firmware think it will solve your issues.
Could someone point me in the right direction? In the SDCard burning software, do I have to have selected different options like "force erase to all" ? Which options do I have to select in order for it to wipe and downgrade to stock 6.0? Any help would be appreciated. :-)
Thanks!
-Marcus
Originally posted by scooter2014 View PostYou best to use the burning tool that flash img. better then sd card maker just need male to male usb and reset pin depressed to get it seen on windows works better that way.
Thanks again,
-Marcus
Originally posted by tht View Post
Two small issues so far, It sure is a Memory Hog that is for sure and The Default Launcher is persistant had to edit the build.prop to be able to use another Launcher.
What you have exactly edited at the build.prop to get an other launcher working ( for example Nova)?
May be it's
ro.HOME_APP_ADJ = 0
instead of
ro.HOME_APP_ADJ = 1
Originally posted by Endur View Post
Can confirm that, every different launcher force close, and the log shows at this time wallpaper service not running.
May be it's
ro.HOME_APP_ADJ = 0
instead of
ro.HOME_APP_ADJ = 1
As said, have tried a lot, the best stock 7 Rom is still 7.1, third revision, easily working with Nova Launcher, stable... Here..
http://chinagadgetsreviews.com/downl...-tv-box-4.html
I got my H96 Pro+ Last week , was already updated to 7.1. My first problem was screen size, there didn't seem to be an option to adjust this in the settings. Then by chance I opened Droid settings ?, and there it was, so problem solved. I'm now trying to find a way to connect it to my Lan rather than Wi-Fi, can anyone show me how. I would also love to change the launcher, any recommendations.
if your wifi signal is poor you could use home plugs and use the Ethernet port?
the launcher is functional enough for me you can add your side loaded apps to the home screen and I'm using a usb wireless ri8 keyboard with mine and its v good. the right mouse button on it allows you to go back a page in chrome so browsing is easy even my shield doesn't allow that so in that sense its better.
Originally posted by lyricidal View Postnew firmware just posted today on here: http://4pda.ru/forum/index.php?showt...ost&p=57278083
I have uploaded "clean" version with no preinstall apps and removed USB Burning Tool "licence" folder requirement. (where it requires licence folder overwrite), links to follow at https://mega.nz/#F!TVtSEZpJ!7JIKzxWWhR-8S7kb3pTElw
not sure why they did "3+16_kodi17.0RC3" instead of "3+32_kodi17.0RC3" or if just a typo... will upload a re-partitioned version after my dentist if needed,
There are currently 2776 users online. 1 members and 2775 guests.
