Also, the .img file is the firmware. So, just updating with the .img means replacing existing firmware. In other words, stock firmware remains intact.
[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by mitchschaft View PostMost people don't do the toothpick method correctly. Disconnect everything; even hdmi. Push down the button, plug in the usb cable to the port that allows data, keep holding the button. It'll pop up in the amlogic usb burn tool after 15 seconds or so.
If you really did brick it (doubtful), open it up, find the 4-pin serial port, solder 4 pins to it since it probably doesn't have the pins in it. Buy a usb-to-serial adapter. Connect it to the pc using a terminal program and come back when you get that far.
Have you tried the Amlogic Toolset done by a member here? It's updated and works well compared to Amlogic's version:
http://freaktab.com/forum/tv-player-...-0-funeral-day
https://forum.xda-developers.com/android-stick--console-computers/amlogic/opensource-amlogic-tools-t3786991
Sunwell t95k pro box 2/16 LTM 8830 flash NAND BWCTASC21G18G. Ask for help. The box is blue led on the front, and red in optical. . I can't find the firmware. All firmware stops at 7-8% in USB Burning Tool. A photo of my box. I received it already in such state as is, already with a problem of inclusion. What firmware will suit me?Last edited by rashmaster; 12-14-2018, 17:32.
Hello all,
I have a t95k pro 2gb/16gb. It works fine with stock firmware t5kp0006. I am unsure of the wifi chipset on it. I am wondering if I will be able to upgrade to android 7.1 from android 6.0.1. It has a capital "A" logo on the top with a leaf like this youtube video https://www.youtube.com/watch?v=mA5bNw4dwvo
I tried 7.1.2 v1015 for my model, that gave up wi-fi and bluetooth plus the screen seemed to be shutting off. I tried the superceleron rom and that failed at 7 percent, while only plugged in to usb. I tried the android 7.1 rom for the m92s plus and that did not even boot at all.
Any input would be greatly appreciated regarding, which, if any, firmware to try to install on it. Thank you in advance.
https://imgur.com/a/s1YrKWN POISONATV Here we go with a new Version of the PoisonATV Firmware. We are supporting S905X, S905W, and S912. This Thread is about the S912 Version and only this Version will be supported in this Thread. CHANGELOG -Based on Tanix Firmware -Root access (on or off) -Removed more settings (Useless
Originally posted by v43 View PostThank you for that, it would be nice if we had some user input from t95k pro users in that thread. It seems promising though!
Findout what cpu r u having S905X or S912 and also ram, ddr or lpddr?
Just my 2 cents
Thank you for that, well the t95k pro is not a model that I have heard to ever have an s905x cpu on it and I bought it with the understanding that it had an s912 chip. Is there a way to easily check whether the unit has ddr or lpddr without opening up the box itself?
The thread on xda developers had some issues with the older poison rom with the t95k pro but this new one seems much improved, as per the thread anyways.
There are currently 1698 users online. 7 members and 1691 guests.
