[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
    Hello guys.
    Sorry for my english I am french. I have a box t95k pro but impossible to install the rom superceleron. I have an error with usb burning tool :
    [0x10105004]Romcode/Initialize DDR/Read initialize status/Error result.
    I have upgrade my firmware to 7.1.2 with usb burning tool but no problem. The installation of the software was a success. help me
      Originally posted by alone4 View Post
      Guys I cannot get over this issue.. please help.
      My device is T95U Pro
      Sent from my SM-G930F using Tapatalk
      Greetings! I also have a T95U Pro. Please flash your T95U Pro using the following ROM:
      I hope this helps.
        Originally posted by soldiaz View Post
        Can you guys recommend the device T95UPRO and this rom here?
        The T95U Pro is a reliable box. I use it with this ROM:
          Originally posted by cdzo72 View Post
          Any plans on updating to Android 7?
          The following ROM for the T95U Pro uses Android 7.1.1
            Originally posted by Iraklion View Post
            Hi everyone please. can someone link me 3/32 gb firmware of t95u pro?
            Try, http://www.mediafire.com/file/fo33g2...P6522.rar/file
              Originally posted by fantonima View Post
              On my T95u pro, after flashing this rom, i have led status changing color from green to blue continuously...there is a way to stopping it?
              Try this ROM:
                Fixed Links in the 1º post!
                  Tried the link for the T95Z Plus and received the error "[0x10105004]Romcode/Initialize DDR/Read Initialize status/Error Result"
                  The MD5 code for the img file is e4d99d018bb81738753e7a9e7c69a723 which isn't the same as the one quoted in post 1
                    hmm weird let me check
                      I just checked, and the MD5's are correct!
Name:	Captura de ecrã 2022-10-31 144158.png
                      Click image for larger version  Name:	Captura de ecrã 2022-10-31 144136.png Views:	3 Size:	25.5 KB ID:	830914
                        I checked the MD5 of the .img file within the zip file and not the zip file itself. Sorry for the confusion.
                        I've managed to bypass the error that I mentioned above by unchecking 'Erase Flash' & 'Erase bootloader' and the rom loads successfully except that I have no wifi nor ethernet connection. My box has the 8830 wifi chip & now I've read other comments in this thread that this rom is incompatible with this wifi chip.
                        Thank you for searching out the roms and re-establishing the links but it looks like they are of no use to me.
