[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by mitchschaft View Post
Hey Everyone,
I flashed my T95Z (3G+32GB) with this rom and now it appears bricked :/
Before I could connect no problems with USB Burning Tool (that's how I flashed this rom), now device won't connect, there is no boot logo or HDMI signal but there is a solid blue LED light.
I've tried various stock images including one I have used successfully before via SD card & toothpick (success was with USB burn tool before though). I have made a few attempts to boot via TRWP on the SD card but to no avail (Not sure if I'm doing the TWRP thing right to be honest). Also tried burn card maker with an image that worked previosly.
The box does not seem to boot from installed recovery or from any recovery on the SD card :/
I don't know what wifi chip I have, any advice or tips would be greatly appreciated!
Thanks!
(Windows 7 Pro)
Hello, I'm using this ROM since a year now on my T95Z Plus (2GB/16GB) and I'm very happy with it.
But yesterday I changed some values in the build.prop file, because I wanted to get a higher resolution in the Netflix app.
This was not the best idea, because my T95Z is now stuck at the bootanimation.
I can still access the build.prop file through Linux (Armbian, booted from SD card) and change the values.
So could someone with a running T95Z maybe please read the values out of the build.prop and post it here?
The build.prop file is in the /system/ folder, which can be found in the root directory.
These are the values I've changed:
Code:ro.product.model= ro.product.brand= ro.product.name= ro.product.device= ro.product.board= ro.product.cpu.abi= ro.product.cpu.abi2= ro.product.manufacturer=
Originally posted by TJ4312 View PostThese are the values I've changed:
It would be great if I don't have to reset everything or flash the ROM again.
Hi! I'm new at forum. I do not get T95z plus 2/16 gb's firmware. My pc not recognize it, impossible doing with usb burning, stop at 7%. I'm tried do through SDcard doing
short circuit nand. It does not advance upgrading. Can you help me know my correct firmware?
I attached some photos of my TV Box...
Thank you very much for all the help you can give me. I'm very frustrated with my problem. pd: Sorry for my bad english.
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
I started having a problem with the stock firmware where the internet connection on both Wifi and Ethernet cable would be on and off. I re flashed a couple of stock versions and kept encountering the same problem.
i have given this version a go and I’m now on the third day without losing a WiFi connection at all. Very pleased. The only issue I have is that Ethernet does not work. The icon comes up that it’s connected at the front of the box but in the settings there is no connection. I see from the comments that a couple of others have had this too. Can I ask if anyone found a fix?
massive thanks again to superceleron
I have a T95K Pro and tried this ROM but cant get the WIFI to work. It cant even switch on. Always stays off. I opened the box and the WIFI chip says
longsys ltm8830
Im kind of new to these boxes but i tried different rom's without getting it to work.
Anyone have any ideas on how i can solve this?
Originally posted by scooter2014 View Post
Kinda not to happy on your comments so hears some pointers on posting even if your not happy about items in a custom build.
1- Donate then your opinion would matter little more.
2- Read the entire Thread posts. It says launcher everything the same and the fixes (over 20 on this alone not counting his kernel fixes but hey if its not better then stock go back to stock then. )
3- Read the Ftmc thread and your missing the items put in by Superceleron (including passthrough last build) But if your happy with Kodi latest great. Youll notice it works a bit better in Superceleron build because of a few kernel changes.
4- Read and learn how to change the logo. It is posted we wont tell you this time and give you a chance to learn how to use the search menu on Freaktab.
5. Developers work hard making fixes to improve your crap device. A little comment saying Thanks for your excellent work goes along way more then just bashing the build.
Happy New Year.
Originally posted by TJ4312 View PostI can still access the build.prop file through Linux (Armbian, booted from SD card) and change the values.
I have managed to aget a T95K Pro up running with CoreELEC 8.90.4. I sure would like to know information how to get an ARMbian boot on this device. Can you provide the link to such an information? TiA.
Originally posted by mitchschaft View PostHere's the latest rom for the T95K Pro. Eggyfresh got it from the developer:
T95KPRO-2GB-v1015: https://mega.nz/#F!5lZSHbYB!gkWtSxJZTsiN0g24tRIyoQ
Originally posted by mitchschaft View PostYes, it updates everything. I had to reinstall TWRP as well.
There are currently 2747 users online. 1 members and 2746 guests.
