[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
    Guys, anyone tried to stream 4k movies from some kodi addon with this build? I tried spmc and ftmc but no luck. Got voice, no picture. Any idea?
    Sunvell T95Z Plus
      Originally posted by jit18 View Post
      If you want to try out Nougat on this box you can flash the rikomagic mk22 Nougat rom...
      Mk22 for 2/16 boxes
      Mk22 plus for 3/32 boxes
      No Display and maybe not WiFi and Bluetooth but those can be fixed
      Mk22 plus for 3/32 box works good and fast, but wifi is differ: 3/32 box is with LTM8830 but MK22 plus is with AP6xxx.
      So is there any idea how to add 8830/qca9377 drivers to mk22 plus firmware?
        Three questions :
        1.Is Bluetooth working?
        2.Is Lan working?
        2.Do you have twrp installed?
          Three questions :
          2.Is Lan working?
          1. Yes Bluetooth is working ! (Strange)Update: Audio devices are not working properly
          2. Lan is also working
          3. I did not try TWRP, but it is possible ,I think, to load it from SD-card.
          Only WiFi is not working, when I shift wifi switch in settings, it comes back itself.
            Is this Rom compatible with T95Wpro?
              Looks pretty much the same hardware to me, seems like sunvell only made one box but changes the wifi chip and the cover every few months so people think there are many different boxes..
                Quick temperature fix.
                  Hey guys,
                  I have a Sunvell 95 plus Box with superceleron Rom.
                  Runs like a Charme.
                  I replace the Ftmc Player build 19 with the newest Version from this Forum here.
                  Now I cant Run It from the Home Menu Button.
                  The error is cant find app.
                  Is there any possibility to fix IT?
                  Thank
                    Hey guys
                    It would be nice to have superceleron Rom adapted to 3/32 version of T95Z plus with 9377 wifi, or adapt this wifi driver to MK22 plus RKM Rom. Otherwise it seems that for this device there is no one good working firmware???!!!!
                      Hi everyone!
                      First off all, great forum!! Great community! congratz!!
                      I need some assistance! I own a sunvell T95V pro tv box. i've checked and there are roms for every box (T95z u k x etc etc) but not for the V. can someone help me understand if i can use either this roms, or must wait for the right one?
                      Many thanks in advance!!
                        Originally posted by andmaster View Post
                        Hi everyone!
                        Its a Sunvell 2/16 DDR3 S912 Box.... Just the same as all the others, just fancy on the outside...
                        You can use every Sunvell S912 Rom out there... They use one for all Firmware (i haven't seen anything else).
                        The only problem you could get is that your wifi might not work... (thanks to the wifi chip lottery)
                          Thanks a lot jit18 for the quick answer!!! i suspected that, 'cause what i've already read in the forum, but is good to confirm.
                          As i'am a complete noob, and i dont have problems in admit it is there a way to back up the actual factory rom, and if something goes south with the new one, is just a matter of "restore" the factory one?
                          Thanks a lot again!!
                          Regards
                            Regards
                            You need to run twrp from sdcard and make a full backup of your actual firmware... (ON SD card!)
                            Someone wrote a how to with links.. I can't find it now but its easy.
                              Hi everyone!
                              On Own Risk!
                              Did upgrade my t95v pro, can be read for useful info on page 32 in this thread.
                              -tv99
                                Hello!
                                Thanks for your great Work!!!
                                One Question i still have is why you used the FTMC 16.1 Build 19 ? Does it have a special Reason? Can I update to lastest Version from the Forum here without any Issues?
                                Or is that the most stable Version for our S912 Boxes ?
