[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by Blackburn29 View PostI rebuilt this ROM for the LTM8830 wifi chipset. If anyone is interested in this, let me know.
Whats the difference with your Rom, i would be interested in trying it.
thanks.
I don't know if anybody has any experience with this but any help would be very much appreciated. I have an unbranded clone with the 8830 wifi chipset. It arrived with the v32 stock firmware, the wifi was slow but worked okay, the ethernet would connect to my network but not to the internet. I would say the behaviour was like bad dns config but changing to static IP and configuring different dns to point to google didn't help either.
The v33 firmware fixed this issue for me but came back once I flashed Superceleron's rom. Unfortunately it also killed my wifi and wiped my wifi MAC address, what I'm really trying to do though is just get ethernet working. I've had a scour of this thread and elsewhere to no avail. If anybody has any ideas I'd be really grateful at this point lol.
Okay fixed it anyways. Putting this here for any lost souls who have my problem in the future.
Use AMLogic Customization tool and unpack the kernel (in tmp\level 1\ folder of program)
Add that to Superceleron's rom and repack
Flash to box and lose root and all the additional packages
Get latest SuperSU binary and put on sdcard
Get TWRP for T95Z on XDA forums. Rename it recovery.img and put on sdcard
Toothpick method the sdcard to get into TWRP
Go into terminal and enter "echo SYSTEMLESS=false>>/data/.supersu"
flash supersu binary from sdcard and reboot
I can see I've lost all the additional apps with this rom but is no loss tbh although I gotta get xposed on there still. I'm hoping I'm not losing additional benefits of this rom but we'll see. Can't be worse than staying on stock, everything seems to be running silky smooth so far at least so yipee. Frankly screw the company putting out the boxes I bought, they weren't fit for sale with borked ethernet >.<
The short answer to my problem in shorthand is this, will try help anybody with this if needed send me a PM:
Flash stock firmware v33
Use TWRP to backup latest kernel
Flash superceleron's rom
Reflash kernel backup
Re-root through TWRP with previously stated command in terninal.
Also worth trying for other issues if you think newer kernel may benefit.
Thank you for the excellent ROM!
My stock ROM, that came on my Morrivoe T95K Pro broke Netflix 4.9.0 and higher (with error 13 when attempting to stream) and I couldn't get the xPosed Framework to install.
Your image solved my problems and allowed me to run Shaw FreeRange TV (using RootCload and ReceiverStop) and the latest version of Netflix. I also really liked that the pause button on mini-keypad now pauses Netflix too.
FYI:
I too tried the Netflix for Android TV v4.0.2 and found it failed to start a stream with tvq-pg-103 1.10.5005 error message.
There are currently 3253 users online. 0 members and 3253 guests.
