[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
    nop to busy this days!
      Ok The force be with you !
        Hi all, I've installed this on AP6330 and temperature is between 70 & 80c while in use. Is this too high & I should use different firmware? Thanks for any help in advance
          It wont get higher, the cpu will slow down. Try to add some hole and/or air ventillation to the box.
          By the way, have somebody removed the original heatsink and white thermal goo? Is it hard to remove?
            superceleron
            Thanks for the ROM, working great on my recently purchased T95Z plus.
            I bought this item with wifi not working out of the box. After a little Googling and with the help of you and this forum it turns out the seller had installed the wrong firmware which was meant for the later wifi chip.
            After installing your ROM everything is up and running and wifi working great.
            Im an active XDA developer, so as pay back to the community I have compiled the latest TWRP v3.0.3.0 and added system_image backup. This allows your ROM to be backed up and restored. It also allows RAW system images to be flashed using the INSTALL button in TWRP.
            I have created a TWRP flashable system image of your ROM, saves faffing with USB sticks and Sd cards.
            TWRP can be flashed with an existing installation of TWRP or RASHR and then the SYSTEM IMAGE can be flashed with TWRP.
            Hope somebody finds these useful.
            TWRP_3.0.3.0_T95Z
            SUPERCELERON_V1_FINAL_TWRP_SYSTEM_IMAGE
            Thanks.
              Well that is a nice work on twrp
              If i update the rom i will include that twrp .
              Nice job
                I cant seem to passthrough dts hd or dolby true hd. Is there a fix for that? DTS HD MA only core DTS is played and TRueHD only PCM-
                If I ask to output RAW audio no sound is played.. Any idea for a fix?
                  @superceleron can you make the ROM for devices with wifi chip LTM8830
                  stock ROM for LTM8830:
                    if i have some free time i will look at it... i simple cant test it since i dont have the box anymore!
                      I think there are many people who will test the rom
                      I'm ready to check and write a review
                        Absolutely. I would love a Superceleron Rom tweaked for the LTM8830 WIFI Chip. Don't get me wrong; I really like SC's custom Rom even if I don't have WIFI and BT. I wish I had it though.
                          @superceleron
                          First let me thank you for the time you put into creating this build.
                          I do understand that since you longer have the hardware it will be challenging bumping up further fixes/updates, but I do have a "theoretical question", since I see you have released an AndroidTV builds for the Beelink GT1/ AlfaWise H96/ S92/ Mecool BB2/ Vorke Z1, being the same S912 hardware (though with different RAM) also with stock Android 6, would it be possible for these sunvell boxes to get an AndroidTV build ?
                          Thanks,
                            Hello all,
                            New user here and was getting frustrated with the power and menu issues.
                            Trying to add the firmware change to my T95KPro unit and having Temperature testing out of range error??
                            [0x30702004]Uboot/temperature testing/get result/out of range
                            Using USB burning tool and USB from laptop
                            Any assistance greatly welcome
                              Originally posted by kwuw4sale View Post
                              @superceleron
                              Thanks,
                              Yes is possible!
                              But with some limitations like no proper rgb fix since i cant use my kernel without losing led control and display.
                              Also even with the stock kernel it will lose the ability to control the leds, it stays in 1 solid color!
                              Originally posted by JayMo_T95K View Post
                              Hello all,
                              usb burning tool, check "view->temperature setting" and play with it!
                                Yes is possible!
                                Thanks for the reply, just speaking for myself, but benefits of getting an ATV build does overweight keeping the front the clock
                                so by losing LED control and display, you mean it will be empty (turned off) ? or will behave randomly (random colors and numbers displaying) ?
