[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by tsubasa42 View PostHello, I have disabled Deep Color but I still have the green flash. Would you be kind enough to tell me how to solve this RGB issue please ? It is very annoying...
Did you read the 1º post? i can make a kernel with that but you will loose the clock display, led control and you cant use the launcher....
If you are using my rom theirs 2 launchers... change to the other, before you flash the zip.......
I have a update.zip but dunno if it flashes on the stock recovery you may need to flash twrp 1º ... and then i will give you a script for you to put in /system/init.d for enable the fix on every boot...
But you really should start thinking in getting another tv, because if you buy another box you are going to have the same problem, this is not a box fault box your tv firmware fault....
superceleron
Do you think you update your t95z rom soon or not?
I must buy the beelink or not?
There are currently 2078 users online. 0 members and 2078 guests.
