[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
......Last edited by superceleron; 13 February 2017, 16:22. Reason: No need to make a alarm... this wont kill the box.. simple flash the other if this one don't work! there are 2 versions of this boxes, the older one with the 6255 and the newer ones with the 9377..
superceleron
Does this rom use the official Google Vending apk? I noticed the 0007 stock rom used a Play Store apk not from Google and also would mount system as rw and uninstall the official vending.apk if installed.
Also when you are referring to the RGB Fix, are you talking about the color space(16-235)? Kodi is too dark with this box.
Originally posted by superceleron View PostIf you are using my rom theirs 2 launchers... change to the other, before you flash the zip.......
I have a update.zip but dunno if it flashes on the stock recovery you may need to flash twrp 1º ... and then i will give you a script for you to put in /system/init.d for enable the fix on every boot...
But you really should start thinking in getting another tv, because if you buy another box you are going to have the same problem, this is not a box fault box your tv firmware fault....
Originally posted by tsubasa42 View Post
Thank you very much for your answer ! I currently have the official firmware. So if I flash with your Rom, the launcher won't work ? How can I do so to use the box? For the TV i'm sorry but I can't change it. I do that for a friend... I ordered for her this box and I'm so annoying to not have a solution yet. Can't I use your script directly on the official Rom ?
If you need a permanent fix, well you have to complain to the box maker.....
no you cant use my script and kernel on the oficial rom.... yes one of the launchers will stop working the same that is on the stock rom... but theirs 2 launchers... use launcher3...
I have installed your Rom. Thanks for your great job! Is it possible your script for the RGB issue please?
There are currently 2094 users online. 0 members and 2094 guests.
