[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
i have opened the box and will test now. there cant be any air circulation. the box is a big design fault.
from my point of view it is also possible to remove the whole board from the case. you just have to remove the glued wifi antenna film from the case. should not be a big deal.
has anyone tried to remove the cpu cooler?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
i read in other forums that the box is much cooler with this rom: https://androidtvbox.eu/new-firmware...p0032-release/
can anyone confirm? whats the reason for this temperature difference between the roms? newer kernel?
Originally posted by satand View Posti have opened the box and will test now. there cant be any air circulation. the box is a big design fault.
You have a different WiFi chip in yours, however I can not tell which one of the 3 variants it is.
Originally posted by jseeley View PostMaybe instead of placing your device on a solid surface, place it on top of something breathable that would allow for better ventilation. What about drilling 1/16" holes in the top housing away from that heat sink shield? Or wouldn't it really matter?
Originally posted by jseeley View PostWith this Rom, would it be possible to update FTMC to Build 20 or even 24? (I have the T95Z Plus with LTM8830 wifi chip.) Would we see any improvements over Build 19? Thanks so much.
Originally posted by lyricidal View Post
Yup you should definitely be able to update FTMC build. Definitely some improvements if you take a look at the change log in its thread. I've updated my T95Z and T95K with it.
EDIT: I just realized that AML was AMLogic! Duh! So I can use the General/AML build 24. Thanks.Last edited by jseeley; 05 March 2017, 18:36.
I also have the 8830 wifi chip.
Originally posted by batkinson001 View Post
Which wifi chip in the t95z plus does this ftmc support?
You can get it here : http://freaktab.com/forum/tv-player-...lk/575588-ftmc
Ftmc Wifi? FTMC its a spin-off of KODI
There are currently 5413 users online. 0 members and 5413 guests.
