its strange because when i had mine(already gone) it dint overheated, idle was always between 45 and 49cº at usage max at 60ºc to 63ºc (my testers also) so is puzzling...
[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by superceleron View Postwell no problem with the rom, since its stock with a few tweaks/fixes! even the kernel is the stock one!
Try stock rom and see if it does the same(i bet it will)
I have found that the box heats up fast while streaming anything be it in kodi, the browser, or any other a app. It takes longer to heat up if all you are doing is watching something local off a hard drive or something.
Originally posted by superceleron View Postyes is the design of the box... it should have more vents etc..... :/
I unable to remove the board to see about removing the grating on the bottom to open up the vents on the bottom a bit better.
i tested this rom, hoping the bluetooth will work with my mouse and keyboard....no luck there, i blame android 6
vnc also not working with l2tp psk....i blame android 6
network connection through ethernet does have better bandwidth, by 20-30%.
this rom feels snappier than stock
but, loosing the navigation bottom menu which i see as a must have, i reverted to stock rom.
something else, i did not manage to make hbo go run on ethernet on this rom, although on stock it did (same xposed framework involved)...i wonder why?
there was a request for ethernet up/down button on this thread; a simple solution is to install quick terminal apk which has an option to use own commands for that, such us ifconfig eth0 up/down
although i did not see an advantage (highs/lows<1 for me) in using this rom it is very nice to have an alternative! thank you superceleron.
Originally posted by superceleron View PostDamn that is really not normal.... when you 1º installed it was so hot?
I restore Stock Rom : Idem. 60-65°C at idle
I open the box. Motherboard outside the box. 57°C at idle. It's still pretty hot !
I see the white foam between CPU and heatsink as described by batkinson001. I think that this foam not doing his job correctly.
MK809 III - Geekbuying december 2013
Originally posted by potard View Post
I restore superceleron ROM without any extra apps: same temp 60-65 °C at idle
There are currently 3487 users online. 3 members and 3484 guests.
