[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Hi guys I've been looking all over the forums. I have a t95k pro s912 the dark colors are really dark compared to any other device I have. Tested all HDMI cords different TVs I come to the conclusion that there's something that the firmware programming that is not allowing the colors to work properly is there a fix for this. My t95u Pro does not have this problem.
Hi everyone! I need help. I try to watch streams from torrent sites. I have a dedicated app (as video app), a torrent app (as service) and libtorrent (program).
I does not work. I have a feeling that it is the s912's arcitecture wich does not works with the database (i am no tech guy at all)
Any idea? Any recommendation? Anyone who solved a problem like mine?
I had to turn off xposed because I had issues with a tv app. Can superuser privilige (or the lack of it) couse it?Last edited by drbodyjr; 26 January 2017, 21:35.Sunvell T95Z Plus
hmm no, i dont use torrents... its not very nice in my countryso i leave it alone!
But upload it somewhere i will have a look with time, im not going to test on t95 since that one now are in my kids room so im not going to touch it... but i will test in another aml they are all +/- the same thing!
Neither do I (since I use kodi), but sometimes I would really love to watch better quality or more stable streams...
The repo's adress is repo.movieshark.xyz. I wanted to use ncoretv, this needs kizstorrent and libtorrent files, which installs automatically if i install the tv app. With installation I get kizstorrent error, but the app is still installed/enabled. When I want to run the tv app, I get libtorrent error....
thank you in advance!
Sunvell T95Z Plus
superceleron
I'm doing intensive research since 2 days now about the sunvell T95Z Plus wifi issue. I found usefull info. On a forum I found that the WIFI drivers in now included on the Amlogic source site
last file
wifi-fw-2016-08-18-5f5fae7239.tar.gz
drivers call qcom9377
the folder contain many files and I don't know what exactly what iIneed to use to make wifi work
If it's on the Amlogic site mean that there is a new revision of the q200 board and more people will face this problem.
I can't find on the internet my original firmware version T5ZP0030 (board q200_9377) , there is no leak or any trace who build that firmware. My box is a true Sunvell T95Z Plus and not a no name copy.
I,ve try to email Gearbest to know if they have that firmware or sale Sunvell box with newer board. I didn't get any reply
I've downloaded amlogic customized tool and extract the latest img t5zp0010 I clearly see that qcom9377 is not included.
My skill customizing firmware and linux code is low. but I would like to include in a custom firmware and make my box work like it supposed
can you help me on that case
I've build be USB A to A cable and I have the Amlogic USB Burining tool. I'm ready to try thing
Anyway without WIFI my box is useless
Thanks!
Well i dont have the kernel source of this box, and my kernel source already have that driver so i dont need it... the problem if i compile a kernel with my source you guys will lose the display and the led's and the stock launcher because it need the led's to work...
So im with my hands tied for now
Originally posted by superceleron View PostWell i dont have the kernel source of this box, and my kernel source already have that driver so i dont need it... the problem if i compile a kernel with my source you guys will lose the display and the led's and the stock launcher because it need the led's to work...
All that you should need to do is edit your mkern.sh file to point to the new dts and dtb which will be generated when building the kernel. Then just build the kernel.Attached Files
Originally posted by Kingvampire View PostMorning guys, i have the same wifi problem;
my mac address is: 02.00.00.00.00.00.
I have flashed the stock firmware but the problem persist.
my model: zenoplige t95z plus.
Somebody can help me?
There are currently 2867 users online. 1 members and 2866 guests.
