i did same using the pc and amlogic flashing utility
[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by superceleron View Postyes its the official google vending!
nop rgb fix is not that, that is the brightness fix you read in the changelog
I don't feel safe using my google account and I believe the link below to be the package hijacking the official play store app.
Originally posted by jsergio123 View Post
I installed your rom and must say its much better than the stock rom but it stills shows a secondary "Play Store" version 1.0 app installed. The package name is "com.example.googlestore" and if I disable it then I can no longer launch google play store from the launcher and the play store will no longer be in the app draw but I can still launch the official play store app manually.
It need to have that one for the shortcut in default launcher, you can remove it but then you will loose the shortcut in the launcher and you need to use another launcher to see it... your choice...
i would like to use a DVB-C stick with mit T95Z Plus with your rom and tune in kodi. is a DVBAPI implemented in the kernel? someone implemented it in cyanogenmod for wetek: http://wetekforums.com/v/index.php?p...h-kodi-live-tv
do i need a special DVB-C stick because of driver issues?Last edited by satand; 20 February 2017, 21:35.
Originally posted by minixfreak View PostCan you make this work for t95z plus with 9377 wifi please ?
currently suffering from high temps making kodi unusable for streaming, local media playback is fine with the top of the box removed.Last edited by batkinson001; 23 February 2017, 13:32.
Originally posted by MayesBZH View PostHi,
i tri to flash your rom. I bloc at the step with the av bouton that i press. Nothing detected on the burning tool.
Now my box is not detected on my tv in hdmi but boot with the hours etc...
Any solution?
If it have the hours is because is booting, so maybe a stuck reset button(i hope you dont pressed to hard on it, they sometimes are fragile)? or HDMI not well connected ...
I dont see any other way, since you dint flash it...
Originally posted by satand View Postthanks for your answer. is it possible to implement it?
never heard of that one!
There are currently 1844 users online. 0 members and 1844 guests.
