But im little busy now with some rom problems!
[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by Savynorth View PostI've just installed the rom on my T95Z plus . Runs smoothly and feels quite fast . However , wifi is dead . I've tried re-flashing the ROM or factory-resetting , to no avail . Could it be a chipset issue ? I used to have no wifi related issues prior to flashing the V1 Rom
Originally posted by batkinson001 View PostThe rom by superceleron doesn't work on the newer t95z plus (both sunvell and clones) due to it having a different wifi chip. Mine for example, has the 8830 wifi chip and had no wifi when I flashed the rom to it. I have gone back to another custom rom that does work but doesn't have any improvements that superceleron's does
Which custom Roms are compatible with the newer t95z models ?
This guys rom works with my box. I am using an older build from early last week. It's very close to stock.
I don't know about a 9377 wifi chip but cpu-z identifies my board as a q200_9377 or something... My box has the 8830 WiFi chip which I only found out about by opening up the box, screws are behind the feet which are just stuck on.
Buen dia, quiero dar las GRACIAS al amigo supercelerom por esta excelente ROM. Ahora les comento que pude recuperar mi LeelBox T95K PRO gracias a esta excelente ROM y al procedimiento de recuperación que esta aqui en el post. Mi equipo estaba bloqueado porque intetente actualizar el firmware con la version original de Sunvell T95K PRO, pero gracias a ustedes pude recuperar nuevamente mi TV BOX y esta funcionando al 100%. GRACIAS nuevamente...
Originally posted by jkjelds View Post
This will output hd on none widevine l1 but as you said android tv version still not supportet..
http://199.175.53.21/netflixlatest.hdonly.apk (Force Enable HD only)
http://199.175.53.21/netflixlatest.ultrahd.apk (Force Enable UltraHD only)
http://199.175.53.21/netflixlatest.u...thdolby5.1.apk (Force Enable UltraHD with Dolby 5.1)
5.1 doesn't work but too lazy to investigate. I'll just download those I want in 5.1 and view through Kodiak.
Many thanks to superceleron for this wonderfull ROM.
However, my box is running pretty hot.
60-65°C at idle.
Is it normal ?
This temp seems to lowered T95k Pro performance
By default, Geekbench gave me a 1540 multiscore.
If i set the box in the freezer for 30 minutes and runs geekbench immediately : score = 2150 !
I don't know if the temps are the same with stock rom, I haven't test it before.MK809 III - Geekbuying december 2013
hi any reason why im having issues with this rom/box i got the box yesterday put this rom on box this morning and ive just watched a 4k film no problem and straigh after ive just put another 4k on it wont play heavily freezing and random pixalating, so i try a 1080 same result freezing and even 720 freezing temperature of box is 78deg c when i stop mocie and look in cpu-z ?
There are currently 2091 users online. 2 members and 2089 guests.
