Well you found your problem!
[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Hello,
Thanks a lot for your good job ! Very good rom !
But I have a question, a problem.
On the original firmware, the video IMAX_Pre-Show_Never-Compromise_2015_4K_A_51-thedigitaltheater (download here http://thedigitaltheater.com/index.p...show-trailers/) works fine.
On your img, I've got only the sound.
Why ?
Why ?
Originally posted by Kingvampire View Post
I have copied the wifi files of LTM8830 in my box but i have the same problem. =(
Superceleron, first of all thank you for the great rom.
I realised few weeks ago the videos are not as sharp(little blurry) as by the media player like using my pc binded to the TV .
It is similar with your rom and the original rom as well.
I tried kodi16.1 kodi 17, spmc, ftmc, lots of video settings in them, but none of it helped about it. I feel the 1080p sample videos looks like a 720p or maybe a little better...
I found this on the net, maybe this is the root cause the "issue":
http://www.phonearena.com/news/How-t...-issue_id63536
https://forum.xda-developers.com/lg-...-beta-t2957648
Could you tell me what is the actual setting in your rom?
If it can be set sharper or completely remove edge blurring, that would be the most ideal solution. I can help you to test it if needed.
Originally posted by Teddybee View PostSuperceleron, first of all thank you for the great rom.
I will check the kernel if theirs something there!
Originally posted by xneon View PostSometimes, I see some lags on h264/h265 with FHD or 4k movies...
Any solutions ?
I use WD USB3 Harddisk.
Originally posted by superceleron View PostHmm that is for KK and not MM and the video sharping in done in the kernel and i never seen that in this devices kernel(maybe i missed it...)
A found this:
There are currently 1870 users online. 1 members and 1869 guests.
