[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Do I have to use this software for flashing: http://androidpcreview.com/how-to-us...firmware/3749/
In his case which of the usb ports is the otg port?
Sorry for the amateur question, as I said I am absolute beginner.Last edited by drbodyjr; 07 January 2017, 08:39.Sunvell T95Z Plus
Originally posted by drbodyjr View PostDo I have to use this software for flashing: http://androidpcreview.com/how-to-us...firmware/3749/
Here: http://freaktab.com/forum/tv-player-...urn-tool-2-0-7
Use the USB port at the rear for flashing (on the T95U) rather than the one on the side.
1) To flash, disconnect EVERY cable (including power) on the TV box.
2) Fire up the USB burning tool on the laptop (or PC)
3) Connect a USB-2 port on the laptop to the rear USB port on the TV box
4) Hold the power button in for several seconds on the TV box until the USB burning tool gets a connection
5) You can re-connect the power cable on the TV box at this point if you wish (sensible)
6) Proceed with the flash
Before you start, I suggest that you use RootExplorer to take a copy of ./system/media/bootanimation.zip and store it somewhere safe. You may find it useful once you have installed this ROMLast edited by Yemble; 07 January 2017, 17:38.
I've a T95Z Plus. Can I connect it to my home theatre with optical cable to have dts and dolby digital 5.1 sounds ? How can I update it with this firmware ? Because if I open USB Burning Tool, load firmware and connect box to my laptop, nothing it's recognizedLast edited by aragorn73; 07 January 2017, 18:14.
Ok, I am a bit scared to brick my box so I will prepare a boot card as well.
I downloaded an amlogic bootcard maker (might be an old version though) and the latest stock firmware from this forum (0004). I followed the instructions of chinagadgetreviews, but... how do I make a boot card? The program just makes a fresh format of my microsd, but I can not find the files I do have to copy on it.
I might be hopless. Please give me detailed instructions!Sunvell T95Z Plus
http://freaktab.com/forum/tv-player-...278#post621278
I know they are different boxes but on that they are all the same.
Just follow that, or course use this rom and not the rom on that post....
Thank you Superceleron, I really appreciate your help!
Now I have everything to make magic. An a-a usb cable, your rom, the burning tool and of course for the backup plan the bootcard.
I can make it tomorrow, after work. I hope the next time I write to you will be the one when I buy you a beer. :-)Sunvell T95Z Plus
Hey everyone, first post! I'm starting to get into these boxes and I've run into a problem that I can't seem to find the answer too. I have a T95U Pro which I flashed SC's rom too but now I can't get the ADB authorization window to pop up.
I have tried "Revoking ADB Permissions", and resetting the ADB server but no to avail. I've found some sort-of related solutions online like deleting /data/misc/adb/adb_keys but the file doesn't exist. I would assume since I haven't authorized anything on the device yet.
Has anyone ran into this or could offer some help? I'm off to work for the rest of the day but I'll get back into it tonight.
Thanks!
There are currently 1640 users online. 2 members and 1638 guests.
