[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Hi Guys,
I have a T95K Pro, which i have initially tried to install the custom firmware using the memory card + toothpick method.
Here are the steps i did:
1. downloaded the firmware of superceleron
2. downoaded usb card maker software
3. formatted my sdcard to Fat32, and used cardmaker software to create the flashing card.
4 inserted flashing card into the tv box
5. Then it booted up to a yellow android and went black screen. and nothing happened after that. (waited for like 15mins)
6. Then attempt to do the tooth-pick method for 2nd time, it does not boot at all. only the blue LED is lighted up.
Next, then attempted to flash with USB Burning Tool 2.0.8 x86.
1. Loaded usb burning tool
2. selected firmware and loaded it.
3. click on start
4. plug tv box and it connected fine.
5. flash process starts, but failed at 4%.(default temperature range setting 20-40)
6. Did 3 times, all failed at 4%. (temperature range disabled, 20-60, 20-80)
Error code received
[Err]--[0x10303004]Romcode/Switch status/Identify/Error result
Any kinds souls or experience flasher able to shed somelight to this?
Thanks!
3. click on start
Error code received
Thanks!
Hi guys,
I buy this box and flash with your firmware with this post
I use TRWP and the last supersu zip (SuperSU-v2.79-201612051815.zip) but i cant see the icon app in android
in TRWP, I see boot image not found when i install supersu
Someone have a good version of supersu for this box ?
Thanks =)
Log (ok its already install but super su from google play dont see root access)
- Mounting image
- Creating paths
mkdir: can't create directory '/su/bin': File exists
mkdir: can't create directory '/su/xbin': File exists
mkdir: can't create directory '/su/lib': File exists
mkdir: can't create directory '/su/etc': File exists
mkdir: can't create directory '/su/su.d': File exists
- Removing old files
- Placing files
rm: can't remove '/su/bin/su': No such file or directory
rm: can't remove '/su/bin/daemonsu': No such file or directory
rm: can't remove '/su/bin/supolicy_wrapped': No such file or directory
rm: can't remove '/su/lib/libsupol.so': No such file or directory
rm: can't remove '/su/bin/sukernel': No such file or directory
Boot image patcher
- Finding boot image
--- Boot image: not found, aborting
sukernel v2.79 (ndk:armeabi-v7a) - Copyright (C) 2014-2016 - ChainfireLast edited by asgardcfr; 27 April 2017, 12:44.
Well it's getting better and better with the WIFI ROULETTE..
My Sunvell T95U Pro has a AP6335...
Luckily for me the only side effect seems to be the lack of 5 GHz... (Superceleron Rom).
Is it only Sunvell that uses whatever WiFi Chipset is currently available or cheap or do other manufacturers use the same method?
Originally posted by jit18 View PostWell it's getting better and better with the WIFI ROULETTE..
There are currently 4207 users online. 2 members and 4205 guests.
