[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Ive installed the final SC ROM and can't get the wired Ethernet connection working here... WiFi works ok though. I've tried static and DHCP, and although it says "connected", it just doesn't work.
Has anyone had the same issue or managed to fix this? It worked fine with the stock ROM before I updated.
well only if i get one... dunno if that will going to happen!
Thanks for the 2gb/16gb ROM here. It's definitely faster and more stable than what I was using.
Have you experienced any wired Ethernet issues at all in your testing though? Or perhaps any ideas how I can get it to work?
It's strange because:
If I choose DHCP, I can see the IP on my Tomato router but Android says not connected
If I choose static, I can see that on the router too and Android says "Connected", but it doesn't actually work.
I even tried manually adding it via ifconfig on the commandline but with no luck.
Any help would be greatly appreciated.
Thanks.
Well try 1 disable the wifi even if its not connected.
If that dont work, enable developer options and then enable "legacy DHCP".
Hi, I enabled Developer Mode but there's no section for "Networking" under Developer Options.
I only see General, Debugging, Input, Drawing, Monitoring and Apps.
Any suggestions?
Cheers.
This is a problem in the kernel I believe. I solved it by doing this:
Flash stock firmware v33
Get latest SuperSU binary and put on sdcard
Get TWRP for T95Z on XDA forums. Rename it recovery.img and put on sdcard
Toothpick method the sdcard to get into TWRP
Use TWRP to backup boot partition to sdcard.
Flash superceleron's rom
Reflash boot partition backup in TWRP
Go into terminal (still in TWRP) and enter "echo SYSTEMLESS=false>>/data/.supersu"
flash supersu binary from sdcard and reboot
Sorry if this is lacking much explanation of how to do this. If you need a bit more info I'll be happy to go into more detail if needed. Sorry at work at the moment so can't spend too much time posting
Use TWRP to backup stock kernel to sdcard.
Reflash kernel backup in TWRP
When you write "backup stock kernel to sdcard" which partition you mean in twrp screen :boot ? system ? or what I have to tick there??? What is Kernel???
