[ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - 2Gb/16Gb - SCV1 Final ROM
Originally posted by manvel View Post
When you write "backup stock kernel to sdcard" which partition you mean in twrp screen :boot ? system ? or what I have to tick there??? What is Kernel???
Hey Everyone!
I have a question or two if someone could find the time to answer I would greatly appreciate it. I currently have 4 T95U Pro's 2G/16R, I want to flash TWRP onto them to keep a copy of one of the systems original stock rom to flash to the other 3. I don't want to flash another rom just want to keep the original rom to flash to the other 3 T95U Pro's. I have to clone the system and am trying to save time by creating a backup to then restore onto the others. Has anyone had success with TWRP on the T95U Pro 2G/16R? I do not want to brick any of these but would like some possible feedback. Also if someone has had great success with a backup and restore along with any suggestions or advice they may have. Thanks!
Kindest Regards!
Please deleteLast edited by VoidnWarranties; 02 November 2017, 20:53. Reason: I didn't have the USB cable plugged in the right slot.... DUH
Okay - I know this an easy question for somebody - but simple question. Before I flash this on a new box - how do I back up the current ROM? I booted with the toothpick and can get to that screen but there is no backup option. Inside the current ROM I have gone through a backup - but I have a suspicion that is not the "just in case" backup that I am looking for. Sorry for the question but hope someone can help.
Thanks,
Originally posted by mc72 View PostHi all - I have a bricked T95K SE (not Pro). I am having a tough time finding a flashable firmware in .img format, anyone be able to help me? I got sent the wrong firmware which I flashed and now it won't go into recovery, I do however have the SD card method FW so another solution would be a program which forced recovery then I could update the SD files thru USB. I have such a program for MXII, anyone be able to help me out? Got this beautiful new brick here lol :S
is there a solution for this issue as I'm facing the same?
If I'm understanding this right, you could try putting the TWRP recovery image from the link below on to your sdcard (ensuring the name is recovery.img)
http://freaktab.com/forum/tv-player-...945#post634945
Then turn on the box while pressing in the toothpick, this should get you into TWRP recovery. From there you can change from zips to imgs etc and flash.
If you get really stuck the imgs will be contained within the zip files if that helps. You could try extracting the recovery.img from one of the zips and flash it through TWRP. Just food for thought if anything.
Playstore Update Fix
Normal Install google service framework & google play service
(Backup old Phonesky.apk file before you replace)
copy Phonesky.apk to system/priv-app/Phonesky folder
set permission Phonesky.apk 0644
reboot
enjoy..
http://www.mediafire.com/file/4qys49...tore_tvbox.zipLast edited by Beerussss; 01 December 2017, 14:18.
Hi guys,
Im new on android boxes. I had purchased a Sunvell T95Z 3gb/32gb - Android 7.1.1, Try to use this ROM, but its bricked now.
Only shows the blue light on the box when connected to the power, tv and computer doesnt recognize it.
- Try the boot sd card. Nothing happens. only the blue line. Try the toothpick on the AV to put in recovery. Nothing happens.
- Using the boot application that I used before to install this ROM, but now the PC doesnt recognize the box. Nothing happens.
- Tried different PCs and different versions of the boot application, but nothing.
This is a brand new box. Any advises?
Most people don't do the toothpick method correctly. Disconnect everything; even hdmi. Push down the button, plug in the usb cable to the port that allows data, keep holding the button. It'll pop up in the amlogic usb burn tool after 15 seconds or so.
If you really did brick it (doubtful), open it up, find the 4-pin serial port, solder 4 pins to it since it probably doesn't have the pins in it. Buy a usb-to-serial adapter. Connect it to the pc using a terminal program and come back when you get that far.
Originally posted by mitchschaft View PostMost people don't do the toothpick method correctly. Disconnect everything; even hdmi. Push down the button, plug in the usb cable to the port that allows data, keep holding the button. It'll pop up in the amlogic usb burn tool after 15 seconds or so.
on usb burning tool method have you tried using usb port beside lan port?
unplug all cables
unplug the power cable as well
just connect usb to pc cable
Maybe it help
Originally posted by Beerussss View Post
This rom for 2gb/16gb box
unplug all cables
Maybe it help
There are currently 3515 users online. 1 members and 3514 guests.
